wanted cad drawing of 1200 ute
From perth airport
anyone got one ?
Posted on: 2011/3/5 7:45
perth airport parking
Datsun 1200 ute A14
Re: wanted cad drawing of 1200 ute
What the hell are you up to now?
seen the dimensions here if your interested?
http://datsun1200.com/modules/myalbum/photo.php?lid=18734
Posted on: 2011/3/5 8:02
From mandurah
hes going all out ,rack and pinion i think ,maybe jordy should make one to "test" on my coupe ahah doesnt matter then if it drops a tie rod !
Posted on: 2011/3/5 9:37
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Check out the Body Alignment charts:
Posted on: 2011/3/5 17:45
Front engine crossmember bolts
* 11 mm holes
* 8 mm forward of strut centerline
* 60 mm front-to-rear spacing
* 656 mm left-to-right
* 405 mm from rear bolt to Front core support mounting hole
Strut Tower to Strut Tower centers
* 936 mm width
Posted on: 2011/3/5 18:06
From windsor, sydney
hi guys maybe this can short cut the rack and pinion exercise
jpg  Image061.jpg (134.84 KB)
9512_4d792c00bc705.jpg 600X800 px
Posted on: 2011/3/10 19:52
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
From perth airport
cheers ddgonzal
Posted on: 2011/3/10 21:41
Datsun 1200 ute A14
