a12 rebuild what pistons??
From vic
hi i am planning to rebuild my a12 engine but was wandering what brand pistons and were to get them also normal cast or Hypereutectic pistons also should i increase the compression if so to what also i will be using 98 octane fuel.
Thanks!
Posted on: 2011/3/9 9:32
Re: a12 rebuild what pistons??
From Brisbane, QLD
Try and get hold of some a10 pistons if you want more compression, cast ones should do the job wouldnt bother with fancy ones
Posted on: 2011/3/9 9:40
From vic
are a10 ones same size and height also i might run a turbo later on so i guse uping compression is just dumb thats y i was wandering if Hypereutectic pistons should be used for turbo engines!
Posted on: 2011/3/9 9:42
From Brisbane, QLD
a10 pistons are pretty much the same as a12 except they have no dish. If you plan to run a turbo later just use the standard a12 ones
Posted on: 2011/3/9 9:45
From vic
will stock pistons be able to handle boost?
Posted on: 2011/3/9 9:46
From vic
are pistons hard to find for this engine and the big end bearings are acl brand good?? what other brands are there?
Posted on: 2011/3/9 9:48
From sydney.nsw
i've got rebuild kits for a12/14/15. a12 come with flat top pistons +060(1.5mm)oversize. kits include; pistons/rings/bearings/gaskets/timing chain & tensioner.or sell separately.a12 kit $420 + freight.cheers
Posted on: 2011/3/9 9:52
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From vic
what brand is this rebuild kit is it new in sealed box??
Posted on: 2011/3/9 9:55
From sydney.nsw
all good quality brands and NEW. Have sold heaps of kits to other dato member on here.(hastings/king/durapro/endurotec brand names).cheers
jpg  engine kits a12..jpg (170.66 KB)
9764_4d77569401a61.jpg 980X735 px
Posted on: 2011/3/9 10:04
Edited by bige on 2011/3/9 10:29:48
A10 coupe piston ARE A12 pistons:
* 12010-18021 PISTON SET-with piston pin (std size)
But only A12 GX hi-gas models used them. All other A12s used dished pistons.
Posted on: 2011/3/10 2:57
