Running rough !!!
From Delaware, USA
Hello everyone, My Datsun has new spark plugs,wires,cap,rotor,timing adjusted,new pc valve,gas filter and air filter. Turns right up in the cold,choke works perfectly and stays nice in idle. But when I'm @ a light and hit the pedal, it feels like i'm dragging a trailor !!! Then it coughs a couple of times and then it get and goes. If I try to keep it around 55 mph, it feels like it wants to stall but if I hit the pedal to the floor it runs good!!! The car just passed inspection. It has the original A12 with all his hoses and everything. Any ideas ? I hate driving a slow car :(
Posted on: 2011/3/8 13:18
Re: Running rough !!!
From A-TOWN
Check the timing or sounds like the carby mite be blocked, take the air cleaner off while its running, rev the #OOPS# outta it then block the inlet of the carby with something that will seal it but not get sucked into the carby if that makes sense. The suction will help clean out anything stuck in the carby and mite fix your problem. If not perhaps a carby rebuild.
Posted on: 2011/3/8 13:25
From Delaware, USA
I got home and took the carb apart and cleaned it and put it right back. Adjusted the valves and the carb and rechecked the timing. Test drove it and it ran a little bit better but not 100% !!!
Posted on: 2011/3/9 0:27
From south coast nsw
mine was showing similar symptoms the other week,the element in my fuel filter seperated and was doing jack.i blew the carb out twice before i found the probem.the jet thats located under the accelerator pump arm was getting filled with crap.its easy to forget to blow this one out.
its this one i mean.
Posted on: 2011/3/9 3:43
From Delaware, USA
I air blew everything on the carb plus carburator cleaner.I took out all the jets. Today this morning it was sneezing more. On one ocasion it stayed acelerated and it didn't want to go down. So I kept driving to work until I noticed it wasn't stuck no more. Can it be the distributor ? It used to be points but I installed a Petronix to convert it to electronic along time ago! It's driving me crazy,
Posted on: 2011/3/9 13:24
From mandurah
did you use compressed air on a carby ? or did you just blow the parts clean ?
cos putting pressure through the carby will damage the needle and seat and mess up the float level and cause the carby to either overfill the bowl or not fill it enough
so be carefull with preesurised air and fragile parts like carbys :)
good luck !
Posted on: 2011/3/9 13:34
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Delaware, USA
Yes I did use air compressor on my carby and noticed the float kind of high when I got home :(
Posted on: 2011/3/9 21:53
