distributor vacumm advance
From vic
hi i am putting my carby together and i just saw a pic on the net and was wandering were the distributor vacumm addvance goes wen i got the car it was plugged uin the cirlce diaprham kind of thing circled in black but the pic says it goes in the carby vaccum circled in yellow so were should i attache the hose also its a manual choke!
also the accel pump leaver rod circled in blue it connects near the throttle cable cam right but why dosnt mine line up properly with lever once placed in there??
Thanks!
jpg  dattso carby.jpg (130.85 KB)
14954_4d7a020c348c4.jpg 1434X700 px
Posted on: 2011/3/11 11:10
Re: distributor vacumm advance
From Melbourne, Australia
vac advance normally connecte to yellow circle, diaphram thing is not normally on the carb thoguh, what is the other half of that connected to?
not sure what part of lever doesnt line up?
Posted on: 2011/3/11 13:30
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From vic
the diafram connect to a thrrotle cam were the yellow advance is suppost to go is were the altitude compensator was plugged
so once i plugg the dizzy to yellow vaccum should i connect altitude compensator to diafram
maybe the owner before we connected it wrong?
Thanks!
Posted on: 2011/3/11 13:44
yes, I think it was corrected wrong.
The altiude device was added around 1980 . I do not know how it is connected.
The diaphragm in the photo is the Throttle Opener
Posted on: 2011/3/12 3:20
