« 1 ... 33 34 35 (36) 37 38 39 ... 42 »
Re: Project Drift coupe (AKA 1200 coupe )
From mandurah
hmm i used the orbital on it tonight to find that it is lead wiped across the front too ,were the line is ,is where its wiped
so i just bogged it over ,need to buy a 5kg tin of bog next week if i can scroung up enough cahnge hahaha cos the bog ive got is $23 for 1kg and i can get rage for $60 a tin of 5kg ,with hardener !
and it is realy nice to use ,and it just spreads on easy and is easy to sand too
ok so i am going to redo the rear passenger side when i get new bog ,i want this thing done , but im still wondering if i should go for the weld on flares or not ,would make getting the wheels to fit easy and also make getting the shape of the rear wheel archs easy cos they are both stuffed ,then once i weld the flares on i can cut away the old wheel arch to make room for the wheels :D
i want this thing to sit as low as phisicaly possible ,i mean not runnign bump stops and haveing the fuel tank remounted in the boot low :D
and the front is no problem cos ive had it sitting where i want it but it means i need to have weld on flares or funny ofset wheels ,cos the wheels hit on the guards cos of the s13 front end :D
still at the moment im practicing my skills at bogging ,when it goes on it looks #OOPS# house but when its sanded back it doesnt look so bad ,abit more work involved when it is roughly put on to start with but the bog ive got doesnt like holding its form ,and if you get it too hold its form with hardener it decides to go hard too quikly !
also i have realised that i need to pull the front bumper off to take the front apron off so i can reattach the centre piece that i chopped when i was test fittinf my intercooler :(
so if anyone has a apron to rob bits off ide love to swap something for it ! cos the one on my sedan front is stuffed ,got flattened when i cut the front off the sedan :(
if carps finds a coupe to build off ill give him my left over parts and stuff ,and then his build will go alot smoother cos i know now what to find ,buy and what i can and cant score for him :D (no nigel or mik ,not score with him )
so far ide deffs recomend the s13 front end for availability and the skyline diff of cours for the awsome ratio and choises of brakes and tough axles from factory
i have a list of stuff i have used ,and what i would of done differently
for starters i would of liked to use my sedan shell s it was almost rust free in comparison to the coupe ,even though the coupe will look a million times better sideways than a sedan :D
Posted on: 2011/3/9 13:05
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From mandurah
ok so today i got alot of stuff organised !
i was on my way to work when i noticed a nissan exa in maxs wrecking yard across the road form ,work ,went round after work and got
rocker covers
coil cover
coils and coil rack
coil harness
power transistor
CAS
TPS
AFM
idle soleniod thing ,2 peice thig that bolts to the inlet manifold and has 3 bolts holding it on
air control valve thingo
and best of all ! a front wheel drive thermostat housing YEOOWWW
test fitted it and its sweet lines straight up with the radiator ports :D
and tomorrow im going back at lunch to get the cams ,timing cover ,cam gears ,clutch slave cylinder ,clutch master cylinder
also got my bog today ,i got a 4kg tin of rage gold ,with hardener for only $40 ! couldnt believe how cheap it is and after trying it out tonight ,its great ,its nice and smooth ,and easy to put on ,plus its a piece of piss to sand ,takes half the time of 3m bog to sand and 3m was $23 for 1kg when this stuff is 40 for 4kg
good thing my brother is a penal biter ,thats how i got it so cheap
so yea ,got a few spare sensors now and should have a spare set of cams too ! ,might go for the 2 exhaust cams ,they are suposedly bigger than inlet cams so i might use the ex cam im getting tomorrow in the ca :D
hoping to have the roof bogged tomorrow arvo ,then start sanding it back and priming it for paint
still pissed i took all the opld bog out ! ,there wasnt anything wrong with it !
Posted on: 2011/3/16 14:41
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Freo
watch out for those Penal beaters.. they go blind.. ;)
Posted on: 2011/3/16 23:27
A15 PSI Project Motor
'72 CB750k,
From Perth WA AUS
Why does your brother bite penals? you should get some profesional help for him!
Did he bite you? :)
Posted on: 2011/3/19 13:27
Datsun 1200 2Dr sedan.
From mandurah
no he bites pinis's not penal !
and no he hasnt biten me ,dirty ol man you are nigel !
ok so i started on my gaurds last night and almost finished the front of one ,but i have figured out my orbital is sh1t so im buying a ryobi one this week !
i was going to patch my lower sill on the coupe (its rusted right out) but instead im going to use my miricle bog to "fix" it
i will put heaps of time into bits then remember ..... its a drift pig not a street car
so if i go for realy realy bright white you wont notice the crappy panel work !
also started mocking up my rear shockys too ,i am goin to use a set of silvia front struts ,cut the purchs of them and sit them in there ! its will work but i wont have any adjustment
its either that or just buy a set of falcon monroe air shocks and use them
Posted on: 2011/3/20 11:51
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From mandurah
oh and mike ive told him to stop ,hes already blind in one eye ,but he wont listen!
Posted on: 2011/3/20 11:52
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From mandurah
Tonight I ran out of stuff to do on my ute so instead I got abit of work done in the engine bay
Took all the bog out of the fire way and redid it ,then sanded it flat and attacked the surface rust with a scotchy
Go all the bare steel clean and then primered it
Was thinking about buying some spray cans for the enginebay ,cos when I po ainted it last time it looks good ,not a show finish but better than it was
Im thinking black ,cos it hides stuff
Main reason why I want the bay done ,is to put the m oi tor and box back in ,then ill have heaaps of room for my a15 stuff
Posted on: 2011/4/20 15:55
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
black hides stuff but also doent show up oil leaks etc easily.
Posted on: 2011/4/21 10:29
From mandurah
Yea I want blackbut dad wont let me do the car black
He is sponderimg me with tyres so I am doing the whole thing white then im getting it sign written
I dont want sign writting but if dads payin for the tyres ill go with it haha
Tonight I got some more bog work sanded and primed a few spots in the bay and finishs sanding one of the gaurds and a door
Pic tomorrow and more updates
Posted on: 2011/4/21 15:33
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Rosewood, QLD
you guys definitely need to come over for a few days and play with my ute
Posted on: 2011/4/22 13:39
1971 B110 sedan project.
2012 Nissan Micra daily.
