Windscreen removal tips? Front and rear
From The BV in South Aus
Hey guys I'm just about to remove the glass and was wondering how to do it? Does anyone have any advice or tips or things I need to watch out for while I'm doing it? Also how hard are they to put back in with new rubbers. Or should I get a windscreen place to do it?
Posted on: 2011/4/3 5:58
Re: Windscreen removal tips? Front and rear
From Gold Coast
Cut the front section of the rubber out, lift the screen out and simply remove the rest of the rubber. Can be a bit of a pain if they are sealed tight.
To install, use some soapy water and a long piece of thin rope. Put the seal on the screen, wrap the rial around the seal in the part that seals against the body, spray rubber and body with soapy water. Put screen into place and with someone holding pressure from the outside slowly pullbthe rope from the inside. May take a go or two and you can do it with or without sealant, it's your choice
Posted on: 2011/4/3 6:39
From Townsville, QLD
its fairly easy. Just DONT lever the glass, it will just instantly crack. Cut the rubber away and lift it.
Replacing, as wardy said, use rope inside the rubber seal. When pulled through from the inside it pulls the inside edge of the seal through. I used sealant (black sika style) inside the rubber.
Posted on: 2011/4/3 7:36
Fuel lines this week, turn the key by the weekend.....
Thanks guys. Just remembered I've got a gregorys service manual and it says the same thing about install but says to flick it out from the inside rather than cut it for removal. The rubbers arnt that bad and I was thinking if I can keep them I'd try that way. Anyone removed the screen without destroying the rubber?
Posted on: 2011/4/3 12:09
I remove mine by using about 6 wooden clothes pegs (Pulled apart). Insert the tapered end of the peg in behind the rubber (from the inside of the car)and lever rubber away from the frame and slide the peg in behind the frame. I found if you put one about every 2 inches the screen will slowly pop out as you work your way round.
Good Luck
Dave
Posted on: 2011/4/3 13:11
can you buy new windscreens for utes? if so how much do they go for?
Posted on: 2011/4/3 13:32
MUNCH MUNCH PISTONS FOR LUNCH
From cranbourne, vic
i use two smallish flat blade screw drivers and just tuck the inner seal under the frame, working from top center out and yeah as sead, it will pop it self out..
i would suggest go to the wreckers and have a crack at a car with the same style seal.
yes, around $150-$300.. mine cost close to $300 as i couldnt wait..
Posted on: 2011/4/4 14:14
82 1200 ute - daily
89 R31 H.M.A.S. Skyliner - drifter
197? 1200 coupe - new drift project.
85 CMA81 nissan/ud 9.5ton banana back - tow pig for the drifter.
