Ac unit
Hey guy's question tho am what type of ac unit would fit into a datsun 120y....Would a toyota AE100 Fit?
Posted on: 2004/2/2 5:38
Re: Ac unit
A/C from a Datsun 1200 or Datsun B310 (sunny) should fit.
Posted on: 2004/2/2 5:45
Re: Ac unit
From Perth, Australia
how easily sourced are they ?
Posted on: 2004/2/2 5:47
1974 120Y Coupe
40 thou overbored A14
32/36 DGV Weber
5 Speed Gearbox
New Interior (in the making)
My website
Re: Ac unit
So an ac unit from an ae100 wouldn't fit cuz as anb008 said how easily are they sourced....and i'm in the caribbean.
Posted on: 2004/2/2 5:52
Re: Ac unit
Well, here's what you face:
1. Bolting the compressor to the engine
2. Driving it from the crankshaft
These two are where a Nissan a-series engine compressor will bolt right on using factory pulleys.
3. Under-dash unit. The 1200 one is flat, but the B210 dash is slightly curved.
4. plumbing, doesn't matter too much what you source it from (Datsun, Toyota, etc) as you'll have to customize this
5. Condensor (radiator-type thing). Shouldn't be too difficult to fit. Goes in front of radiator.
Most cars have an integrated A/C system, making it harder to fit into another make. But the Datsun 1200 A/C unit was dealer-installed, and bolts under the dash (fans, vents and cooling part is one unit).
Posted on: 2004/2/2 6:01
Re: Ac unit
So all i need is a condenser a compressor, pulley's plumbing and the electrics and my ac unit is ready???
If thats the case i could get the plumbing custom made a condenser and compresser from maybe a gt starlet....I'm thinking the compressor is the thing that the pulley's run off of right?
Thats what is going to give a bit of trouble??
Posted on: 2004/2/2 6:16
Re: Ac unit
From Perth W.A
can you get them with a clutch so i could turn it off and not use engine power when i want to race and things like that or would i have to just take that pulley off the fan belt?
Posted on: 2004/2/2 6:23
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
Re: Ac unit
the "Clutch" is the actual indash switch that turns on the aircon...
when the aircon is off, the pulley just free wheels...
when on, the compressor is driven...
My Factory 120Y logbook shows integrated Aircon... where would I start to find one of THOSE units ?
Posted on: 2004/2/2 7:53
1974 120Y Coupe
32/36 DGV Weber
5 Speed Gearbox
My website
Re: Ac unit
From Perth W.A
probably america
dunno but i know some of the L series cars had them a girl i used to work with inherited a datto from her dad elec windows air con the lot
Posted on: 2004/2/2 7:56
120y Coupe
Re: Ac unit
Yes, all A/C compressors have clutches. As Anb008 says, it freewheels when the dash switch is off.
There is actually more parts than that ... a dryer unit at least. You should get the entire package from another car, and think carefully about how/if it will fit before paying out any money.
And of course it has to be charged with fluid.
Posted on: 2004/2/2 8:09
