Re: CAMBER TOPS!!!
From Melbourne, Australia
Hi Russ,
I might be a little vague here but can you please explain a little more what you did? Was it basically an adjustable strut top that you bought from Ford? Where were the eccentric bolts for? Were they like an offset bolt for the strut top? Keen to hear more details.
Cheers.
russb63 wrote:
hello all when i had a 1200 coupe now owned by supafatto i went ford and bought a EA falcon camber kit which contained the slotted plates and the eccentric bolts i also ran stanza struts and bluebird Lca's,and machined extra thread onto radius rod.BEAUREPAIReS did all my alignments very impressed with this setup hope this helps
Posted on: 2011/4/9 0:01
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
Subject Poster Date
     CAMBER TOPS!!! estyre 2011/4/6 11:56
       Re: CAMBER TOPS!!! estyre 2011/4/6 12:05
         Re: CAMBER TOPS!!! lethal_john 2011/4/6 12:08
           Re: CAMBER TOPS!!! estyre 2011/4/6 12:10
             Re: CAMBER TOPS!!! Anonymous 2011/4/6 12:15
               Re: CAMBER TOPS!!! estyre 2011/4/6 12:19
       Re: CAMBER TOPS!!! levey 2011/4/6 13:03
         Re: CAMBER TOPS!!! estyre 2011/4/6 13:12
           Re: CAMBER TOPS!!! dattodude 2011/4/8 1:14
             Re: CAMBER TOPS!!! dattodude 2011/4/8 1:16
       Re: CAMBER TOPS!!! MaDUtE 2011/4/7 3:16
       Re: CAMBER TOPS!!! levey 2011/4/7 12:53
       Re: CAMBER TOPS!!! datoboy1982 2011/4/7 22:30
       Re: CAMBER TOPS!!! inkjunkie 2011/4/8 3:03
       Re: CAMBER TOPS!!! Shoota_77 2011/4/8 4:05
         Re: CAMBER TOPS!!! Datsunbloke 2011/4/8 4:18
       Re: CAMBER TOPS!!! ed74mnd 2011/4/8 4:19
         Re: CAMBER TOPS!!! dattodude 2011/4/8 4:36
           Re: CAMBER TOPS!!! ed74mnd 2011/4/8 5:36
       Re: CAMBER TOPS!!! LittleFireyOne 2011/4/8 6:09
       Re: CAMBER TOPS!!! Anonymous 2011/4/8 12:40
         Re: CAMBER TOPS!!! estyre 2011/4/8 16:47
       Re: CAMBER TOPS!!! russb63 2011/4/8 22:58
         Re: CAMBER TOPS!!! Shoota_77 2011/4/9 0:01
           Re: CAMBER TOPS!!! russb63 2011/4/9 4:18
       Re: CAMBER TOPS!!! Anonymous 2011/4/9 3:51
       Re: CAMBER TOPS!!! datoboy1982 2011/4/9 6:28
       Re: CAMBER TOPS!!! levey 2011/4/9 9:14
         Re: CAMBER TOPS!!! Shoota_77 2011/4/9 10:24
       Re: CAMBER TOPS!!! levey 2011/4/9 10:48
         Re: CAMBER TOPS!!! Shoota_77 2011/4/9 11:09
         Re: CAMBER TOPS!!! estyre 2011/4/9 11:09
           Re: CAMBER TOPS!!! Shoota_77 2011/4/9 11:23
       Re: CAMBER TOPS!!! dattodude 2011/4/9 12:39
         Re: CAMBER TOPS!!! estyre 2011/4/9 13:09
       Re: CAMBER TOPS!!! inkjunkie 2011/4/9 13:16
       Re: CAMBER TOPS!!! Datsunbloke 2011/4/10 6:46
