Re: SR20det crossmember
From Mudgee NSW Australia
Believe it or not the Sr20 will use the same crossmember as the CA18det. The main problem being is the Sr20 sump will foul on the swaybar = custom swaybar or modify alloy sump $$$$
Cheers Andrew
Posted on: 2004/2/5 12:11
If In doubt run more BOOST
Subject Poster Date
     SR20det crossmember godabaute 2004/2/5 5:24
       Re: SR20det crossmember ca18det_man 2004/2/5 12:11
         Re: SR20det crossmember godabaute 2004/2/6 8:52
