Re: 240K Max negative wheel offset
Are you able to measure one of the stock wheels?
Are you measiring wheel backspace, or offset?
Generally, if you go with the stock offset, or a little less, say within about 1/2" you should have no problems.
8" on the rear should be cool, but i think that the same rim in a 6" width on the front would be much better to drive. [steer]
PM me if you don't know how to measure offset & you will need a bare wheel to do it.
Posted on: 2004/2/7 23:39
Love your Datsun.
Treat it well.
Subject Poster Date
     240K Max negative wheel offset Razor 2004/2/7 23:04
       Re: 240K Max negative wheel offset Dodgeman 2004/2/7 23:39
         Re: 240K Max negative wheel offset Razor 2004/2/8 23:37
           Re: 240K Max negative wheel offset ddgonzal 2004/2/8 23:46
             Re: 240K Max negative wheel offset Razor 2004/2/9 0:19
               Re: 240K Max negative wheel offset ddgonzal 2004/2/9 1:34
                 Re: 240K Max negative wheel offset Razor 2004/2/12 5:19
                   Re: 240K Max negative wheel offset ddgonzal 2004/2/12 5:49
                   Re: 240K Max negative wheel offset L18_B110 2004/2/13 1:34
                     Re: 240K Max negative wheel offset Razor 2004/2/13 4:02
                     Re: 240K Max negative wheel offset Dodgeman 2004/2/13 15:59
