wtd 12a rotary
From Innisfail nth queensland
im after a 12a rotary can any1 help me or no where 1 can get 1
Posted on: 2011/5/6 16:29
help me iv got a 1200 ute after sum1 in north queensland with datsun parts
Re: wtd 12a rotary
I have a custom single 13b rotary that is a halved 13b
of 650cc capacity that was turboed to 280+ hp with a
high ported Peripheral Port housing.
The most expensive part the Eccentric shaft was machined
by Rohan from Xtreme Rotaries the finest in the business.
Originally designed for Light Aircraft but mine was built
for sports sedan racing but the owner ran out of funds.
It will pass capacity requirements in road vehicles both
in turbo or NA not to mention in racing.
In NA the PP housing can make 170hp but with boost double.
However I would suggest a mild extend port turbo.
It cost almost 40% less to rebuild, I have all parts except
the rotors which you could use stock rx5 or rx4 ones for boost.
If you are interested PM me as I will be advertising it soon.
Posted on: 2011/5/7 1:23
Re: wtd 12a rotary
What To Do?
If you plan to turbo it, get the 12A. But for non-turbo Queensland i think allows the 13B, it makes more power and comes in EFI versions.
Posted on: 2011/5/7 1:31
Re: wtd 12a rotary
From Canberra
Ausrotary
Posted on: 2011/5/7 1:34
YLD.18L
Re: wtd 12a rotary
ring mazfix up they've always got somethin, there a bit dear but they'll throw it on a crate for you. i also saw japanauto's advertising a 12a with a 5 spd they will also post to you
Posted on: 2011/5/7 3:57
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
