240K Max negative wheel offset
From Brisbane
Hi
just want to know whats the max negative wheel offset I can fit on my 240K
as I'm planning to get rims from US and their negative offset starts from 1" - 5"
getting 15" x 8" wide
please advise
thanks
Posted on: 2004/2/7 23:04
Re: 240K Max negative wheel offset
Are you able to measure one of the stock wheels?
Are you measiring wheel backspace, or offset?
Generally, if you go with the stock offset, or a little less, say within about 1/2" you should have no problems.
8" on the rear should be cool, but i think that the same rim in a 6" width on the front would be much better to drive. [steer]
PM me if you don't know how to measure offset & you will need a bare wheel to do it.
Posted on: 2004/2/7 23:39
Love your Datsun.
Treat it well.
From Brisbane
I need to measure the backspace...
Posted on: 2004/2/8 23:37
Posted on: 2004/2/8 23:46
From Brisbane
so if I want a deep dish look I will need to get a negative offset for the rims
am I right?
Posted on: 2004/2/9 0:19
Yes, postive offset is what fwd cars have. Deep dish would be negative offset. But 0 offset would also look "deep dish" if the wheels were wide enough.
Posted on: 2004/2/9 1:34
From Brisbane
what sort of tyres can I fit on 8" wide tyres?
I was thinking 225 at the front and 235 at the rear with flares
Posted on: 2004/2/12 5:19
15" tires on 8" wheel?
BFGoodrich Radial T/A
225/60SR15
235/60SR15
Rim Width Range: 6-9"
http://www.tirerack.com - search by size, pick BFGoodrich, which has one of the largest range of sizes, then click Specs.
Posted on: 2004/2/12 5:49
From Brisbane, Australia
my advice would be to wait until you get your flares fitted. Then you can take some reasonable measurements to work out what size and offset will suit.
Once you've done that, it may be worth looking into a Ford front disc conversion and converting the rear to 5/114.3. It would probably be easier to find the wheel size/offset you want in the more common Ford stud pattern.
Posted on: 2004/2/13 1:34
From Brisbane
I found the rims I want with the 4 stud pattern so one problem out of the way...
might wait for the flares then....
Posted on: 2004/2/13 4:02
