Re: mig welder
From Coondle, WA Australia
I have a small 100amp cigweld gasless welder that i have used for everything. Its holding up my shed doors (structural), ive made gates amongst plenty of things.
It doesent give a good clean looking weld, an you get a fair bit of splatter, but they are fine.
But
a proper gas unit is eaiser to weld with and gives cleaner results. im no welder, but thats my experience
Posted on: 2011/5/9 14:55
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: mig welder
rubey, if you look at me, and then look at a gasless mig weld splatter, the weld wins the prize.
Posted on: 2011/5/9 15:01
Re: mig welder
From Sydney, NSW, 2036
I wouldn't waste your $$ on a cheap welder.. it's a false economy, you will end up buying another better quality unit to replace it after it fails. A mistake I made years ago.
Now I use a MigoMag 195 and argoshield light gas. works great, good looking welds.
It has paid for itself over and over again.. a good quality welder should last a life time, so it's a relatively small outlay for long return.
Cheers
Ed
Posted on: 2011/5/10 0:33
81 Datsun ute
Re: mig welder
If you buy a cheap Chinese machine you can expect to end up with a mig gun that you can't get contact tips for and melts when it gets hot, regulator you can't read and doesn't control the gas properly, controls that you won't understand and don't work and a wire feeder you can't get different rollers for. A friend of mine has one.
Posted on: 2011/5/11 11:11
Re: mig welder
From hastings,vic
my mig and tig both cig both work mint
jpg  mig 003.jpg (165.34 KB)
10243_4dca739033060.jpg 625X885 px
jpg  mig 004.jpg (177.66 KB)
10243_4dca73a9a49f7.jpg 729X820 px
Posted on: 2011/5/11 12:32
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
« 1 (2)
