tacho / Ballast resistor question
From Seattle ,WA.
I'm using a 72 engine compartment wiring loom & an A15 coil & electronic distributor, so no ballast resistor which is fine.
The 72 wiring diagram shows the tach leads being fed off the ballast resistor - will this cause the tach to not work since the resistor isn't in the circuit anymore?
If so do I just plug the 2 resistor connections together to complete the circuit?
thanks, Evan
Posted on: 2011/5/10 3:42
Subject Poster Date
     tacho / Ballast resistor question edp 2011/5/10 3:42
       Re: tacho / Ballast resistor question benny 2011/5/10 3:52
       Re: tacho / Ballast resistor question edp 2011/5/10 3:58
         Re: tacho / Ballast resistor question ddgonzal 2011/5/10 4:36
