mk1 golf won't fit my 1200 shocks?
Quite a regular
I must have something wrong here... i ordered mk1 golf inserts and they seem to be slightly to big to go in the 1200 strut.
does someone have a part number for the shocks? or is there a specific 1200 strut i need?
Arrrrrghh!
Posted on: 2011/5/17 4:06
Re: mk1 golf won't fit my 1200 shocks?
From Sydney
I had to remove the paint off my Golf shocks [kyb's] and also hone the inside of the strut tube, to get mine to fit... There is about .5mm in it to make them slide in.
Posted on: 2011/5/17 4:26
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Quite a regular
ok cool.
ill give it ago tomorrow.
Thanks!
Posted on: 2011/5/17 11:31
These are the ones reported to work:
VW Golf/Rabbit
* Golf Mk I insert is nearly 4 inches shorter than stock and will need a simple spacer made to make up the difference in length in the bottom of the tube.
* Strut piston diameter is larger than B110, so drill out the strut-nut and the strut top hole.
Strut Insert Part Numbers
Posted on: 2011/5/18 1:47
