« 1 ... 3 4 5 (6)
Re: CASEYS DAILY UTERUS
From port elliot , SA
turbo set up
Posted on: 2011/4/5 5:35
From Goolwa, South Australia
cant wait to cruise ROCO with old Thelma mang
Posted on: 2011/4/12 11:30
hahaha eventually do a thread on the racecar zac
Posted on: 2011/4/12 12:41
Nice looking turbo setup Casey! Should be fun! Did I send the info on water pluming to you? If not I pulled water from bottom hose via I temp gauge fitting ie 1/8 fitting and then return via opposite side to temp sender in the h75 head as mine had an area to tap into, if yours doesn't u can return it to the heater pipe at the back of the head! Hope this helps Ta nick
Posted on: 2011/4/12 12:53
Car free
From mandurah
Nice setup there casey ! Going to look sick with a weber and a turbo
Best of both worlds !
Posted on: 2011/4/12 13:54
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
yea that head is an old coona i welded my manifold on im also using a h75 and im gonna get rid of my heater box so il probably just plumb it in using those lines in that it will go to the turbo not hte heater then feed into the back of the head. just nutting out how to get it all to fit shes abit tight atm and just finnishing my other motor to bolt it all to
Posted on: 2011/4/12 14:00
well have been flat out with study and havnt touched the ute much. but turbo motor is mostly done. just waiting on a timing cover and i need to get off my ass and set the valves. pre-fitted my manifold and turbo on my current motor. needs a little tweeking as it hits the strut tower. constructive critasism about my manifold would be handy but try not to hurt my feelings i did it myself haha. it is set back that far because im using a webber and it wouldnt fit otherwise.
pondering on painting my bonnet matte black. but when i sprayed the ute the bonnet was the best painted pannel i did haha dont really wanna wreck it. and i also had my state kart titles over the weekend and got a cool shot of myself from that so i figured id share.
jpg  206333_10150151209206859_632116858_6548274_6666033_n.jpg (72.39 KB)
10794_4dd1ea12a8a79.jpg 540X720 px
jpg  205769_10150156433916859_632116858_6592928_7772826_n.jpg (78.14 KB)
10794_4dd1ea2ebe0a2.jpg 540X720 px
jpg  gokarts.jpg (120.14 KB)
10794_4dd1eac4b9f44.jpg 800X531 px
Posted on: 2011/5/17 4:26
From Adelaide Hills
Hi mate, I finaly got one. Its stocker than your mums toaster but if you go for an hills runs over my way let me know.
Cheers,
Daniel
Posted on: 2011/5/21 12:08
righto new black motor whent in the ute last night, just waiting on a new intake/exh gasket to fire it up. yellow motor shows how the turbo set up mounts nicely. need to play with it a smidgen to clear engine mount. but no majour mod. and with my old motor i stored it in my racecar for #OOPS#s and gigles, a bit smaller than the 410ci motor that should sit there
jpg  254225_10150203257821859_632116858_7027569_5694731_n.jpg (66.53 KB)
10794_4df5bd8f88dec.jpg 540X720 px
jpg  248480_10150201781616859_632116858_7011421_5012668_n.jpg (69.74 KB)
10794_4df5bdfda0470.jpg 540X720 px
jpg  248891_10150202536886859_632116858_7018517_5901750_n.jpg (60.42 KB)
10794_4df5be19d44f7.jpg 540X720 px
Posted on: 2011/6/13 8:37
Looking good casey!
Turbo set up looks good mate so be proud you made that :)
I love the pic of the little A in your racecar lol!
Keep up the pics and progress on this build...good work!
Rhys
Posted on: 2011/6/13 11:36
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
« 1 ... 3 4 5 (6)
