« 1 (2) 3 4 »
Re: engine revs when hitting brake pedal? ...worried
From Melbourne, Australia
but more likely the plastic piece that actually pushes it (part of brake pedal) has perished, these are often replaced with a bolt and nut on the ol' dattos these days
Posted on: 2011/5/24 8:36
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Sydney
Looks like the fitting in the inlet manifold is also not blocked off on the little tube that connects the the main fitting. Having this not blocked will lean up the fuel mixture. engine idle will be effected also.
Posted on: 2011/5/24 8:39
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Thanks for the responses guys.
I had a look at the brake pedal where the switch is located and fitted a nut and bolt there (as suggested) since there was an empty circular hole where the switch fits in to, as you guys guessed correctly. (see the red arrow) I'm thinking that mashing the pedal the other night broke away whatever was there before. So the brake lights work properly again! Hooray!
Does it matter where each of the two green wire ends go on the switch? It seems to work either way and I didn't label them before I took it off.
As far as the rev issue...Benny is that valve out of the intake supposed to be blocked? I'm confused.
Cheers.
jpg  a.jpg (195.66 KB)
13419_4ddb7b9a5f75f.jpg 600X399 px
jpg  b.jpg (94.72 KB)
13419_4ddb7ba7863cf.jpg 650X432 px
jpg  c.jpg (148.12 KB)
13419_4ddb7bb47b4fc.jpg 650X432 px
Posted on: 2011/5/24 10:34
wire connection orientation doesn't matter
the valve is the piece half way along the hose,
benny is talking about the small tube from the inlet manifold, it looks like its bent over backwards and twisted to seal it but would be good too see some rubber or sealant over it. This is separate t your brake pedal = engine rev problem
You need to check out the valve (half way along the length of the hose, from inlet to brake booster) i can see it is there in your picture. but you need to make sure this is inserted in the correct direction and is operating
check out if it has an arrow on it and take a picture for us
take the valve off both hose ends and check the mechanism is moving inside it, spray it with heaps of WD40 to clear it out
if you suck on one end you should get flow, if you suck the other you will not. the end you suck and gets flow needs to be the side which is connected to the hose that goes to the inlet manifold
i can not see how any other thing could cause your phenomenon of engine revving when hitting brake pedal
Posted on: 2011/5/24 11:48
1200 Coupe Rallycar
Thanks rally.
Took the valve off and tested it out. It was installed the right way. I blowed on it and it kinda sounds like a duck call used for hunting. Kinda hard to get air out the other side, is this normal? Sprayed a lot of WD-40 in there as well and put it back...the same way of course. One side is brass-ish color (the blow side) and the other end is the same color as the shaft. There were no markings on it that I could tell other than the letters E-K1 whatever that means.
Could the problem be at the ends? Where it meets the booster or the opposite end where it meets the valve on the manifold?
How serious is it to have the engine rev about 500 rpms when I touch the brakes and again when I let go of them?
edit: diagram indicates direction currently installed.
Cheers.
jpg  valve.jpg (160.76 KB)
13419_4ddba4779e1ba.jpg 650X469 px
jpg  valve2 copy.jpg (109.17 KB)
13419_4ddba90a5493a.jpg 650X469 px
Posted on: 2011/5/24 13:28
Edited by datsunbeginner on 2011/5/24 13:48:16
that doesn't sound normal!
shouldnt be like a duck call!
should be free flowing in one direction, and not flowing at all in the other
maybe it is blocked/jammed
when you jiggle in your hand you should be able to hear and feel the slide mechanism going back and forward inside it, it should move very easily, and if it is operating correctly it will not restrict flow much at all, should be like blowing in a maccas straw
essentially there is just a solid cylinder in that valve that slides from one end to the other depending which way air is flowing
you should not be blowing you should be sucking, the engine sucks through that valve to pull the diaphram in the brake booster, you should be simulating that by sucking on the engine side of the valve (by doing this you are pulling the cylinder inside the valve to the engine side, this is allowing flow through the valve, so actually this is the same as blowing from the brake side..... you should be able to suck through the valve from the engine side or blow through the brake side.... and not the opposite scenarios)
edit[] the whole engine rev when brake thing is not particularily dangerous, although its not great, essential you are accelerating and braking together, which obviously is going to increase your stopping distance. you should definately fix this problem as a priority, although personally i would still drive it carefully if i had no alterative.... maybe to a brake place so they could fix it!
Posted on: 2011/5/25 0:12
1200 Coupe Rallycar
well i got a second hand replacement from R-fastmotorsport and installed it earlier tonight. On my test drive the engine still revs a bit when i press the brake pedal and then let go when at idle. I can't tell id it does it at speed. However, the replacement has for some reason made the engine performance HEAPS better. Lot more power when accelerating. Why is this? Cheers.
Posted on: 2011/6/14 14:57
Because it's no longer leaking vacuum (leaking air into the engine).
Posted on: 2011/6/14 15:49
From Sydney
I think there may be a hole in the diaphragm in the vacuum booster. Have you tested to see if the booster holds vacumm yet?
Posted on: 2011/6/15 3:33
1970 KB10 Coupe
S13 caliper b...
What tools do I need and how do I perform the test?
Cheers.
Posted on: 2011/6/15 5:14
« 1 (2) 3 4 »
