No charge??
From adelaide hills
just wondering if anyone can help me out,
im not getting any charge to the battery. ive recently had the alternator recond, and had it tested today to find its all good. got given a voltage regulator that was working and has made no difference
wondering if new voltage regulators can be bought and roughly how much, or is there something else i should look for?
thanks
Posted on: 2011/5/26 7:20
1977 1200 ute aka franky weekender
1979 sunny wagon aka rod the second daily
Re: No charge??
Yes, you should look at the wiring.
If the regulator was "known to be a good one" and the alternator "tested good", then let not worry about them.
First check to see if full battery voltage is present at teh Alternator A terminal (large wire).
Then with IGN key ON, verify if 12V is getting to the T-connector on the alternator.
Note that if your CHG lamp is burned out it won't charge correctly.
Posted on: 2011/5/26 9:04
Re: No charge??
From Perth WA AUS
You can still buy aftermarket regulators, I bought mine from Malz, repco should have them aswell.
Just cant remember the price.
Posted on: 2011/5/26 9:07
Datsun 1200 2Dr sedan.
