Browsing this Thread:
1 Anonymous Users
vacuum advance not working |
From vic
hi been a while because i couldnt log into anything because of dumb virus!
so i have installed a a15 auto choke carb to my a12 engine and i seem to be having some problmes!
i got it to idle good but when you got to drive it will just sputter and die and at idle if held at a certain point starts to sputter.
also i was checking my vacuum advance and i tried sucking and with a air gun thing to suck on the vacuum advance but noting moves is this normal?
will this cause my problem i am having?
with my old carb it never turned of but it was sluggish at low rpm!
also this a15 carb is brand new so accelerator pump is ruled out!!
thanks!
Posted on: 2011/5/30 7:43
Re: vacuum advance not working |
Registered Users Contentmaster Usermaster
vacuum advance won't cause these problems. You can simply plug the advance hose and drive it for years.
New carbs often have a problem -- they have not yet been tested on a vehicle. Instead of trusting it, shine a torch down the throttle and confirm if the accelerator pump is squirting fuel or not -- then you can believe it.
Posted on: 2011/5/30 8:00
From vic
hi thanks i have checked and yess it is squirting fuel just can think why it stalls.
what symptoms does non working vacuum advance cause??
Thanks!
Posted on: 2011/5/30 8:23
Bad vacuum advance causes: 1. (if it is leaking) Vacuum leak, poor idle 2. If it is stuck, 10% loss of fuel economy, slight loss of smoothness on throttle transition, though most people won't notice
Since the carburetor doesn't work correctly, I would return it. You bought it brand new, correct? Get a refund.
Posted on: 2011/5/30 8:37
From vic
yes its brand new so you would say its a fault in the carby?
il see what they say!
thanks!
Posted on: 2011/5/30 8:42
From vic
hi i am back with maybe a solution?
today at idle i reved the engine and held it in the position were it stubles and starts to die just after idle.
and i sparayed some starting fluid in the carby while it was stubling and it smotthed out and reved nice!
so does this mean my jets are to small?
what jest need changing and were can i get them from?
Thanks!
Posted on: 2011/6/1 8:36
It suggests that the jets are blocked, or the air jets are loose
Posted on: 2011/6/1 8:52
From vic
thanks will look into it!
Posted on: 2011/6/1 9:07
From vic
hi so i was checking the carby again and ddgonzal is right about the accelerator pump i thought it was quirting fuel but upon closer inspection i found it to only squirt a drop of fuel which explains the engine cutting out!
so my question is were can i just get a new accelerator pump from without buying a whole new gasket kit! also this accelerator pump looks different to the a12 engine one its brass and slightly different!!
Thanks DD should of listened earlier just missed it thinking it would be good considering its brand new!
Posted on: 2011/6/2 8:47
From Sydney
Isnt this a new carb? Cant you just adjust the pump?
Posted on: 2011/6/2 9:03
