Re: S13 Struts - Firey style!
From windsor, sydney
again
jpg  31052011436.jpg (33.63 KB)
9512_4de4deef5abb0.jpg 640X480 px
Posted on: 2011/5/31 13:28
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
here is the the front track rod modification for anti dive adjustment
jpg  31052011439.jpg (38.50 KB)
9512_4de4df7fee81a.jpg 640X480 px
Posted on: 2011/5/31 13:30
WARDMAN ENGINEERING
CNC machining
0413 595 627
From Cape Town, South Africa
Wards,
What Lower ball joint did you use, and do you mind explaining a little more regarding the anti dive modification as |I see you have 3 mounting options on the front track rod mount position?
Posted on: 2011/5/31 13:37
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
how refreshing it is to see someone is paying attention, the balljoint is a standard stanza unit at the moment but i will be going to a pulsar unit in a custom bilett housing that bolts to a standard LCA , the 3 adjustments alter the height of the front pivot of the LCA triangle, this can be used to control the amount of front "squat"under brakes and therefore front mechanical grip . hope this explaination is sufficent.Wards.
Posted on: 2011/5/31 13:51
WARDMAN ENGINEERING
CNC machining
0413 595 627
From cold toast
thats some serious suspension right there! it also looks like you arent running a sway bar?
Posted on: 2011/5/31 14:12
Yesterday I sourced a set of Nissan 1 Tonner/Patrol, Sani Lower Ball joints that I want to use, They have 4 mounting holes which will help allot with making a mount which I can weld to my LCA that will be made from pipe. Ideally I want to bend the mount +- 23degrees which in turn will mean that the ball joint is almost 100% straight when installed. The ball joint in its straight position leaves allot of space for a mount and clearance to the rotor.
Wards: I understand what you did with the mounting of the front track rod, just trying to get my head around it, trying to find a good explanation of it on the net.
jpg  Nissan1TonnerS131.jpg (127.85 KB)
11688_4de4ec8b6ed27.jpg 800X600 px
jpg  Nissan1TonnerS132.jpg (131.30 KB)
11688_4de4ec938466a.jpg 800X600 px
jpg  Nissan1TonnerS133.jpg (115.98 KB)
11688_4de4ec9a764bf.jpg 800X600 px
jpg  Nissan1TonnerS134.jpg (65.13 KB)
11688_4de4f3e919948.jpg 800X479 px
jpg  Nissan1TonnerS135.jpg (57.32 KB)
11688_4de4f3ef8b501.jpg 800X479 px
Posted on: 2011/5/31 15:03
www.race-tech.co.za
From mandurah
Nice work wards !
Ok so your running a 1200 lca with a stanza ball joint ? Or stanza ball joint and stanza lca ?
As for castor rods ,will stocky ones work well or do they need to be adjustable items
Again nice work
Posted on: 2011/5/31 16:54
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
the lca is a std b110 arm , swaybar is still being manufactured as the rate has not been determined yet ,but it will be a straight torsion bar from a sprintcar with blade adjusters on both ends, the std track rods are ok for the street but they have to be adjustable to achieve the front end geometry needed for circuit racing ,i wanted the ball joint front mount to reduce friction and to allow the arm to move smoothly through its arc without the risistance a rubber bush has, another side benifit is you can pull the wheel foward to gain caster and wheelbase , Racetech your on the right track with that balljoint but a bit heavy duty for my choice
Posted on: 2011/5/31 23:10
WARDMAN ENGINEERING
CNC machining
0413 595 627
From mandurah
Im using s13 lcas and adjustable castor rods ,with the s13 struts will my steering geometry be ok ,whats the best way to have everything for a track car
What I mean is whats the best option for a drift car ?
Posted on: 2011/6/1 1:56
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Townsville, Qld
Yes I do drag things on a bits Wards, procrastination coupled with kick minuscule wage does that to a man but half of the point of the thread is exploring options so thank you for enlightening me to your approach. I can't tell by the 2nd pic but that ball joint sounds interesting. edit: what I mean to say is obviosly since you're changing there is a problem with it but how is it at the moment with bump steer and binding?
Racetech I also like the Patrol one you've tried out as I aim to use this setup off road so the stronger the better, if I was going to run PRC regs I wouldn't have this thread at all
Posted on: 2011/6/1 4:54
« 1 2 3 4 (5) 6 7 8 »
