Re: Diff /axle help....
thanks guys aprrecitate the advice, housings in the bin!!!
Posted on: 2011/5/27 13:41
hey guys,
getting a new housing soon, pulled the axles out this arvo. got me f&^#ed whats going on. the end of the diff housing has a lip and that spacer piece has a grove that mathes the lip, the spacer also has been pressed onto what looks to be a bush behind the bearing.
maybe the pics might help
than i found this pic on the net which makes me think is it a standard thing??
Posted on: 2011/5/30 14:05
From windsor, sydney
that just looks like a major cluster f#$* they got the housing wrong and had to come up with this as a solution to the problem , where is the seal ? is there a O ring in that steel spacer behind the bearing?
Posted on: 2011/5/31 23:27
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
« 1 (2)
