Browsing this Thread:
1 Anonymous Users
Re: S13 Struts - Firey style! |
From Townsville, Qld
Estyre you'll may come across some discussion abroad that what makes a good circuit car should make for a good drift car so the aim is balanced steering that keeps the dynamic camber in the right zones with the addition of as much steering lock as the body can accomodate.
Posted on: 2011/6/1 5:04
From mandurah
Ok ,well with mine setup as is I havnt got a huge amount of lock ,how can I increase the lock ? Adjustment in the steering box ? Any ideas ?
Posted on: 2011/6/1 6:17
77 1200 ute 77mm bore a15 ,12:1 comp ported and reconed h89 head fairly aggro cam ,billet rocker spacers twin 40mm solex carbs on bpro manifold MSD 6al2 with 2 step limiter 4speed 60a box hd clutch 2 inch exhaust locked 4:11 ute diff ...
From windsor, sydney
hi litlefireyone i have changed to rack and pinion steering so in the setup of that i achieved 0.2mm of toe out at full bump i wanted this for circuit racing but i have adjustments in place so i can dial toe in or toe out as required
Posted on: 2011/6/1 8:56
WARDMAN ENGINEERING CNC machining Race Car Fabrication Suspension, Brake, Drivetrain modification TIG welding of all metals 0413 595 627
From mandurah
Woow wards did you shorten the rack or the rod ends? ,or just make mounts up to bolt it in?
Whats the rack out of ?
Posted on: 2011/6/1 9:16
shortening the steering arm should allow for more lock. Some Japenese companies have modified S13\14\15 knuckles for such an occasion.
Posted on: 2011/6/1 11:24
that rack was made for a dato  whats it from?
Posted on: 2011/6/1 11:26
www.datsun1000.comCurrent Dato - 68 B20 ute Previous Datos - ca18det 1200 ute 180rwkw 12a montser port 1200 ute 212rwhp Stocko 1200 wagon
there is a more in depth answer to the rack conversion on another thread a while ago but the short answer is custom modified rack from a opel built holden barina, lca pivot points mooved out 25mm per side and custom height adjustable rack mounts(this is how the bump steer is adjusted)and modified crossmember to suit rack mounts
Posted on: 2011/6/1 14:47
From mandurah
Wards have you considered making more racks ? Ide be keen if you can do it
Posted on: 2011/6/1 17:18
i would be keen to reproduce the rack setup for general sale but the rack is only a small part of the whole package, nearly the whole front suspension from the steering wheel foward has to be played with to get the whole "package" to work in with all the other components , the steering column ,crossmember, firewall,LCA'S , struts, steering arms, etc all have to have some atention to get a harmonious result. read into that a fairly expensive exercise.
Posted on: 2011/6/2 2:44
From mandurah
Will the std steering box work? Instead of rack and pinion?
Im running s13 lcas castor rods and ball joints ,aswell as sunny tie rods (for the extra thread needed when adding wheel track)
Posted on: 2011/6/2 4:00
