Browsing this Thread:
1 Anonymous Users
Re: Silvia-Specr's Project Sleepy |
From mandurah
nice work ,looks soo good ,so the tension rod mounts ,are they fartory or ahve they been taken from a silvia and mounted on the chassis rails ? looks great ,hows the diff going to cope with all that power though ?
Posted on: 2011/6/5 15:10
77 1200 ute 77mm bore a15 ,12:1 comp ported and reconed h89 head fairly aggro cam ,billet rocker spacers twin 40mm solex carbs on bpro manifold MSD 6al2 with 2 step limiter 4speed 60a box hd clutch 2 inch exhaust locked 4:11 ute diff ...
From Vancouver, Wa
the tension rod horn as i call it is the factory one for the car. instead of leaving it as the pull thru tension rod, i opened it up by cutting a large enough hole, then i took and narrowed down the s13 adjustable rod at the pivot end so it would fit in the the bracket since it is double walled. drilled a hole in the bracket. and good to go.
Posted on: 2011/6/6 7:40
1969 Datsun 1000 (B10) 1972 Datsun 1200 coupe (ADVAN) 1981 Datsun 210(B310) 4-door (sr20det) 1971 Datsun 1200 (sedan)
From Vancouver, Wa
Got my new ecm on wednesday, now i need to pull the fuel tank.
210 065a.JPG (123.19 KB)
Posted on: 2011/6/12 5:40
From SE Melbourne
Nice pussy...(what? someone had to say it!)
Posted on: 2011/6/12 6:43
Mildman, Datsunless
From Vancouver, Wa
Summer time blues, lots of daylight but still no time to work on the car, did get the h165 diff in new brakes and calipers, some GAB adjustable rear shocks on, my new teflon intake gasket, ported the intake mainfold, new fuel rail, some 550 injectors, fuel tank is finally finished after three times into the shop. got my fuel pump. made up my fuel lines 5/16. went to the wrecking yard over the weekend and scored some nice black interior pieces, including an uncracked black dash pad. and got stung by a yellow jacket do to nest under the dash.
Posted on: 2011/8/31 7:18
Quite a regular
From South-Africa
That is an excellent build!!!!!! It looks to me all you guys that side are engineers. Keep up the good work like they say in my home language" Dit lyk flippen mooi gaan groot of gaan Huis toe"
Posted on: 2011/8/31 9:48
Lifes A journey Enjoy the Ride
From Vancouver, Wa
well the intake manifold is finally bolted on for the last time, i hope, took the car to the fab shop, to redue the trunk area, so the fuel cell will fit the way i want it too, should turn out good when it's done.
Posted on: 2011/11/5 6:07
From Snohomish, WA USA
Dave, What fuel cell did you go with? I will be going that route as well.
Posted on: 2011/11/6 16:31
Edited by datsa73 on 2011/11/6 17:09:27
'73 2 Door Sedan KA24DR, Twin Webers 38/38 Sync. Crower Stage 3 Cams/SS Valves Forge CP Pistons/ Eagle Rods Eaton M62 SC 10 lbs. Boost / 160hp Progressive Nitrous GM 2 Speed Poweglide/Transbrake 3500 Stall Ford 8.8/Mini Spool/4.11
From Vancouver, Wa
I picked up a ebay special, I went 15 gal. an extra 5 gals of fuel can't hurt anything. has sending unit, foam filled, with the drop down. $186.00 shipped. another $300.00 to have it installed the way i wanted. checked it out today turned out great. http://www.ebay.com/itm/150673848332? ... 2&viewitem=&sspagename=ST
Posted on: 2011/11/12 7:42
Registered Users Contentmaster Usermaster
the extra 5 gallons of gasoline weighs 30+ pounds.
a racing fuel cell is good for safety, isn't it? It is like a regular fuel tank, but with a self-sealing rubber interior seal and a foam type filler to reduce sloshing.
Posted on: 2011/11/12 20:42
