Re: Gearbox problem/"race prep"
Did you check the surface condition of the synchro cone on the gear? I find they can get nicely glazed and the cones then lack real bite on the gear. Spinning it up slowly in the lathe and breaking the glaze with a very fine very flat stone does the trick. Agree that a mild bead blast to the friction surface of the ring is well worthwhile. It helps to have a few rings to choose from as sometimes the mating angles are not perfect.
Get it all right and they really bite hard. Also last a lot longer as they don't slip near as much.
Hope this helps
Posted on: 2011/6/11 10:14
Subject Poster Date
     Gearbox problem/"race prep" diymark 2011/6/10 11:18
       Re: Gearbox problem/"race prep" benny 2011/6/10 12:05
         Re: Gearbox problem/"race prep" diymark 2011/6/10 12:38
           Re: Gearbox problem/"race prep" clyons8 2011/6/10 13:02
       Re: Gearbox problem/"race prep" levey 2011/6/10 13:38
       Re: Gearbox problem/"race prep" revhead001 2011/6/10 14:05
       Re: Gearbox problem/"race prep" diymark 2011/6/11 5:53
         Re: Gearbox problem/"race prep" Weekend1000 2011/6/11 12:11
           Re: Gearbox problem/"race prep" Minisprint31 2011/6/11 14:00
       Re: Gearbox problem/"race prep" ddiesel 2011/6/11 10:14
       Re: Gearbox problem/"race prep" DATUTE1 2011/6/11 10:43
       Re: Gearbox problem/"race prep" R-fastmotorsport 2011/6/11 11:12
