« 1 (2)
Re: Will 5speed fit into 4speed trans tunnel of sedan?
1200GXman wrote:
My experience here is some people think they know how to fix or repair a gearbox only for you to install and get some gears running against each other when driving.
Ok I must admit this was some cheap backyard mechanic that I used to save money.
Poor man pays twice.
Posted on: 2004/2/12 12:02
Love your Datsun.
Treat it well.
From Gold Coast Aust
Thank you for the help and look foward to the email I need internals I have heaps of cases Some of the interals are no longer available through nissan Aust so any help would be good thanks.
Posted on: 2004/2/12 12:04
Datsun 1200
Keepin' the past in the future
From South Africa, Bloemfontein
Yes. I paid twice.
My poor dad paid with money, time and frustration with my mother's 1984 Renault 5TS gearbox.
they came out with a 5 speed.
One morning my dad reversed out of the garage only to find that something broke inside and split open the casing.
The gearbox was removed 5 to 6 times.
Due to repairs and then there is a winding in some gears and then there is gears running against each other making a grinding noise,etc.etc.
Eventually a 4speed was fitted and it is working now.Although it enjoys leaking a little bit of gearbox oil.
My experience with gearboxes is "IF IT BREAKS THROW IT AWAY AND BUY A NEW ONE".
I have never ever seen a gearbox that went in for repairs that did'nt come back correct.
Always something wrong.
OK.I know we cannot get gearboxes anymore for our datsuns.
This is what I hate about our cars.The scarse parts.
Posted on: 2004/2/12 12:22
From Castro Valley,CA USA
ok, i have a 73 1200 2door manual trans tunnel car, with a normal shift pattern 5spd installed.
It's tight, but it fits.
I chose to make a custom crossmember bracket so that i could use the stock 5spd rubber mount. The bracket bolts in the stock location on the car.
I removed the reverse switch and plugged the hole because the switch and the transmission mount on the car were trying to occupy the same space.
Posted on: 2004/2/13 3:32
From Christchurch NZ
The bigger 5spds (doglegs) reversing light switch hits but boy are those boxes are strong.
Posted on: 2004/2/13 6:55
Forced Induction!
« 1 (2)
