« 1 (2) 3 4 »
#11 Re: BIGE "CLEAN UP" ENGINE PARTS SALE
bige Posted on: 2011/6/13 8:30
i'll get back to you on std a12 flat tops.cheers
sunny02 have heads call me
#12 Re: BIGE "CLEAN UP" ENGINE PARTS SALE
bige Posted on: 2011/6/14 1:15
racer135, yes i have a set of a12 std flat top pistons/rings.$260 + post. call me. cheers
#13 Re: BIGE "CLEAN UP" ENGINE PARTS SALE
bige Posted on: 2011/6/14 9:33
heaps of used std rocker arm ass/sumps/rocker cover/timing cases/ altenaters/points dizzys/heads/blocks/cranks/cams/conrods etc. and more. cheers
#14 Re: BIGE "CLEAN UP" ENGINE PARTS SALE/ENGINE REBUILD KITS
bige Posted on: 2011/6/14 10:16
Engine Rebuild Kits A10/12/14/15.kits include; cast pistons,rings,bearings,gaskets.timing chain & tension er(gears if needed)can make up kits to suit your needs.all new and good quality. (some kits can have higher comp pistons available as well) can post at buyers cost. Prices start from approx $420.00 per kit to give u a estimate. cheers
#15 Re: BIGE "CLEAN UP" ENGINE PARTS SALE/ENGINE REBUILD KITS
bige Posted on: 2011/6/15 1:43
all pm replied.cheers
#16 Re: Re: BIGE "CLEAN UP" ENGINE PARTS SALE/ENGINE REBUILD KITS
shakn-1 Posted on: 2011/6/15 3:28
have any elec dizzy's? thanks
#17 Re: BIGE "CLEAN UP" ENGINE PARTS SALE/ENGINE REBUILD KITS
bige Posted on: 2011/6/15 4:27
yes, the unknown one with built in module(was in my car and works) cheers
#18 Re: BIGE "CLEAN UP" ENGINE PARTS SALE/ENGINE REBUILD KITS
bige Posted on: 2011/6/16 7:01
BUMP
#19 Re: BIGE "CLEAN UP" ENGINE PARTS SALE/ENGINE REBUILD KITS
KitchNZ Posted on: 2011/6/17 9:18
"A15 +040cast pistons & rings dish (new) $250"
Hi interested in the above,
A) How deep is the dish in these slugs or can you give me the "CC"?
B) What brand / part Numbers?
I have an A15 ex race motor, running A14 Pistons (unsure why, maybe they have have crowns machined down for higher CR?) but one pistons is cracked, and two other have skirts broken off...
Looking for cost effective replacement set of pistons .040" / 77mm
#20 Re: BIGE "CLEAN UP" ENGINE PARTS SALE/ENGINE REBUILD KITS
bige Posted on: 2011/6/17 14:59
pm sent KitchNZ
« 1 (2) 3 4 »
