Browsing this Thread:
1 Anonymous Users
Re: engine revs when hitting brake pedal? ...worried |
Registered Users Contentmaster Usermaster
You don't need any diagnostic tools. Let it sit overnight, then in the morning disconnect the hose from the Booster. It you don't hear air escaping/hissing it didn't hold the vacuum overnight -- that is bad.
Posted on: 2011/6/15 5:59
From Near Bundaberg QLD
The end of the valve which you blow on which doesnt let air come out the other side goes toward the engine
The end of the valve which you blow on which does let air come out the other side goes toward the booster.
Hope that didnt break your thinkbox.
Is the uncovered metal pipe on your intake manifold the pipe which your booster line was attached to?
Posted on: 2011/6/15 10:03
Thanks, Sam-U-El/Racer135 --------------------------------------------- 4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
yea mate the sucking side is towards the engine and the blowing side is towards the booster. Yea that little bent valve is on the intake manifold. Not sure if its meant to be like that, bent that is.
Posted on: 2011/6/15 12:00
---1976 B120 "THE GENERAL REE"--- Former build---1980 B120 Vanilla Ice --- current build
From Sydney, Australia
I agree with Benny. It's the booster. Foot on the brakes at traffic lights and idle rises.. this is the symptom of a booster with a hole in the diaphram.
Posted on: 2011/6/15 12:42
'71 Green 1200 Sedan CA18DET Project 99.98% complete '71 White 1200 Sedan 20,000mi + A14T (twin 40DCOE 30/70 cam, extractors) Website: http://www.shoeys.com
So the hose to the booster goes over that bent valve on your manifold? So system is manifold>bent valve>hose>ek51? valve you took photos of>hose>booster?
Posted on: 2011/6/15 13:10
yea thats correct. Thats the setup.
Posted on: 2011/6/15 13:41
All you have to do is unplug everything from the booster except for the last bit of hose which hooks up to the booster, suck on the hose (dont be a sissy girl, suck directly on the hose) and then put your tongue over the end of the pipe while you're sucking. Stop sucking but leave your tongue on the end of the hose. It should suck your tongue onto the end of the hose and it should stay there without letting go.
And now for all the sick c##ts to make fun of what I just wrote LOL
Posted on: 2011/6/15 14:07
just disconnected the hose directly at the booster and heard a loud hiss for about 1 second. Sounded like when you open a bottle of coke. Also tried sucking on the brake booster hose and my tongue stuck......confused. The brake booster is only 8 months old. Are we sure i have the check valve the right way?
Posted on: 2011/6/16 9:04
Plug the hose from the booster on the end of the valve which doesnt let you blow thru it
Posted on: 2011/6/16 9:43
why should i plug the hose? Doesn't that mean i'll deactivate the brake booster?
Posted on: 2011/6/16 10:58
