« 1 2 (3)
Re: IS THIS CAM FIXABLE ???
From mandurah
The cam is getting fixed ,and the head is now clean
Spoke to them today and he said the bearings were scraped/honed to suit the old cam ,i now am using another cam ,and they ground the cam after the bears werefitted and scraped ,so its kunda my fault for dropping a new cam on them after messures were taken to fit another cam
Anyways its all going back up on saturday for new cam bearing and the cam to be repaired
The reason im getting new cam bearing is cos today I was told to see if the cam would go in with the ca mn gear bolted to it ,i tryed and it was almost all the way in when it got jard so I stopped ,when I got tje cam back out I checked all the bearings and number 5 has a burr in the centre of the bearing
Im not streesing anymore ,after thinking about it ,its not the end of the world and I have faith they can fix my fuk up and then I can get my motor back :D
Cheers for all the help fellas ,things like this happen and neil was very understanding about whats happened and is keen to help me fix it
Cheers :D
Posted on: 2011/6/7 14:44
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From sydney.nsw
good to hear,get it right. cheers
Posted on: 2011/6/7 23:36
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From Near Bundaberg QLD
Dunno whether this would be off topic or not, but i've got an A10 block with an aggressive cam sitting in it (ex speedway car block apparently) which has been sitting out in the rain at my mates place for who knows how long, lots of surface rust everywhere. What would be the best way to extract it without destroying the cam? Any ideas whether a quick chemical dipping and linishing would get it back in shape? Will take some photos of it all ASAP.
Posted on: 2011/6/15 13:46
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
From mandurah
I've heard surface rust pits the surface ,so as you said maybe a dip and linish
Pics would help another though
Posted on: 2011/6/15 14:42
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
Yeah it might come good, It's just getting it out in 1 piece which is my main problem
Posted on: 2011/6/16 10:24
How do you reckon I'd go if i stood the block up in a press and tried pressing it out after soaking the block in some diesel?
Posted on: 2011/6/16 10:35
From Mandurah, Western Australia
Wow that is tight. If you got any penetrene around apply and leave for few days.
Pressing out is probally less likely to cause damage, compared to a big hammer, screw driver, vice grips, stiltson etc.
Could you heat the offending parts with an oxy?
Posted on: 2011/6/16 12:14
Made my own thread: http://datsun1200.com/modules/newbb/v ... id=372277#forumpost372277
Sorry for hijacking this one haha
Posted on: 2011/6/16 12:35
From mandurah
Haha nag put anything up as long as its about cams ,might help me later Haha
Posted on: 2011/6/16 12:49
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
« 1 2 (3)
