« 1 ... 8 9 10 (11) 12 13 14 ... 19 »
Re: tommo's ca coupe
From hastings,vic
will check volume and let u no ben
i think it needs to hold 1000mls
got my oil cooler today,bit of bling
asked local hose man today that was making me some brake
lines for a 1200 ute $135 for three custom in rubber(needed today,ripco couldnt supply till wensday next week)
how much for 1mt of -10 hose same as cooler. $75 per mt
i brought cooler with 3x1mt peaces of hose as seen in pic
cooler,fitting sand filter mount ect for $129
will post some pics of it fitted soon
jpg  oil cooler.jpg (121.31 KB)
10243_4df1df72d3525.jpg 485X564 px
Posted on: 2011/6/10 10:11
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
From SE Melbourne
Oil cooler looks good too!
The CAMS rules for a oil catch can are....
"15. if fitted with any crankcase breather discharging to the atmosphere, each breather be vented into a catch tank
of minimum capacity of two litres for engines up to 2000cc or three litres for over 2000cc. Regulations for
competitions on unsealed surfaces may waive this requirement;"
I'd probably use the space you were going to use for the wiper washer additional to add up to close to 2L
Posted on: 2011/6/10 10:37
Mildman, Datsunless
Is all that in the pic for 129 smackos??
if so, can you get it all in plain alloy finish?
As shooter pointed out ingenious use of radiator heat!
really moving fast with this project
Posted on: 2011/6/10 10:58
From hastings,vic
cooler fitted and tanks fitted
jpg  oil cooler 001.jpg (110.69 KB)
10243_4df21a3b6200f.jpg 726X382 px
jpg  oil cooler 002.jpg (147.18 KB)
10243_4df21a5788f50.jpg 800X600 px
jpg  oil cooler 003.jpg (127.99 KB)
10243_4df21a70762b6.jpg 800X600 px
jpg  oil cooler 004.jpg (153.49 KB)
10243_4df21aaa8b70b.jpg 942X544 px
jpg  oil cooler 005.jpg (120.85 KB)
10243_4df21ac66ec10.jpg 796X444 px
Posted on: 2011/6/10 14:23
Why in the middle and not offset to one side for full cooling effect? Disruption to air flow across core of ic and rad?
How much are new brake lines for a 1200? Steel not braided?
Posted on: 2011/6/10 15:26
From hastings,vic
brake lines braided about $80 each
Posted on: 2011/6/10 23:33
"i brought cooler with 3x1mt peaces of hose cooler,fitting sand filter mount ect for $129"
where from? thats cheap!!!
Posted on: 2011/6/10 23:52
From hastings,vic
EBAY if u look hard enough u will find
looked under oil cooler kits
it was from malaysia
oil cooler ebay
Posted on: 2011/6/10 23:58
From hastings,vic
done a little more
made some alloy covers to clean things up
and some guages to no wot going on when under the bonnet
cur off top grill mount and made a new one,looks alot better
now no gaps
jpg  rad suport 001.jpg (173.06 KB)
10243_4df99a65a93e5.jpg 1202X549 px
jpg  rad suport 002.jpg (103.10 KB)
10243_4df99a7acc024.jpg 643X524 px
jpg  rad suport 003.jpg (120.39 KB)
10243_4df99a9c3577b.jpg 800X600 px
jpg  rad suport 004.jpg (143.27 KB)
10243_4df99ac1457f6.jpg 800X600 px
jpg  rad suport 006.jpg (163.90 KB)
10243_4df99ae0538d5.jpg 1001X747 px
Posted on: 2011/6/16 6:56
From hastings,vic
couple of pics of tonights work
moded lower front panel to fit oil cooler
and to let more air in and made shore the front guards
all lined up
jpg  lower rad suport 001.jpg (197.11 KB)
10243_4dfa092e6de17.jpg 1179X568 px
jpg  lower rad suport 002.jpg (196.14 KB)
10243_4dfa094ce6562.jpg 1190X704 px
jpg  lower rad suport 003.jpg (152.88 KB)
10243_4dfa096e6cfe8.jpg 800X600 px
Posted on: 2011/6/16 14:47
