water pump question
From Rosewood, QLD
if i run an electric water pump and thermo fans can i then remove water pump and stock fan and just put a plate over the hole to seal it up and just run a smaller belt on alternator and crank pulleys?
Posted on: 2011/6/27 3:11
1971 B110 sedan project.
2012 Nissan Micra daily.
Re: water pump question
Yes, sure. I don't know if anyone has done this, but it's what they do on a some racing engines.
Posted on: 2011/6/27 4:12
From Rosewood, QLD
sweet. it will also tidy up the engine bay
Posted on: 2011/6/27 4:16
From Coondle, WA Australia
Ive done this for my engine.
Since I want to stuff a intercooler and radiator in the front, removing the water pump and fan gives me heaps of extra room.
You will still need to run thermo fans though, but some slim line ones will be perfect. I have two from an alfa sudz that I am using.
I took my water pump gasket to a laser cutter and they scanned in the gasket and cut me some from aliminimum.
Posted on: 2011/6/27 4:36
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
water pump pic
picture of the water pump cover plate
Posted on: 2011/7/4 4:24
