« 1 (2) 3 »
#11 Re: My engine is smoking
bige Posted on: 2011/6/28 7:52
thats a bad habit(smoking pot)haha. rings or seals.
#12 Re: My engine is smoking
kululadotgroen Posted on: 2011/6/28 10:21
They are so cheap to freshen up, I'd just pull the whole thing and give it some love...
#13 Re: My engine is smoking
D Posted on: 2011/6/28 11:57
I mentioned VSS due to the take off and then disappearing
as you go but maybe glazed bores due to overfuelling from carbs?
Just make sure you put some reggae & avoid getting high :)
jpg  smoke god.jpg (74.08 KB)
737_4e09b303c3498.jpg 545X637 px
#14 Re: My engine is smoking
Ivan1 Posted on: 2011/6/28 12:29
Don't worry about it DD, mines been like it for years. Just keep topping the oil up.
#15 Re: My engine is smoking
estyre Posted on: 2011/6/28 15:22
It'll stop blowing smoke if you stop filling it up
#16 Re: My engine is smoking
reuby_tuesday Posted on: 2011/6/28 23:36
by kululadotgroen on 2011/6/28 18:21:37
last time i was involved in a budget freshen up, i think it cost me more in beer than rings and seals...
ring-a-rectomey... way forward.
#17 Re: My engine is smoking
ddgonzal Posted on: 2011/7/2 1:45
I finally found my compression tester. Here are the results. These numbers match up to the plug conditions:
#1 oily
#2 fine
#3 burn good, bit lean
#4 partially oily
The valves were adjusted correctly, at least I could get a 12 thousands gauge in each one. Forgot to shine a light on the valve seals, hard to see inside the springs...
#18 Re: My engine is smoking
Rallytwit Posted on: 2011/7/2 2:12
Well looks like the it's time for rings, two weak/ weakish cylinders................should be able to do a quickie ring job in a day: pull the head with everything still attached, pluck the block lay it on it's side and throw some rings in it OR use thicker oil, keep driving it and build up another bottom end. I'd likley go with the hillbilly rebuild...........cuase it's a street car albeit a very nice one.
Tom
#19 Re: My engine is smoking
ddgonzal Posted on: 2011/7/2 2:51
Thanks Tom. I have a shortblock ready to go ... it's not my daily driver so I'm not necessarily in a hurry. I won a best in class award last Saturday in a 850 car show here in Seattle, good thing the engine wasn't running while the judges came by, little did they know..
I was planning on using this head again and found two problems:
1. #1 Rocker is binding, #2 is good.
2. #7 intake valve stem seal has popped up
I guess it won't be too hard to fix those, put a new seal on #7, and swap the rocker shaft for a good one.
it has these type seals:
#20 Re: My engine is smoking
D Posted on: 2011/7/2 5:07
So the bottom end rings are no good DD?
« 1 (2) 3 »
