#1 exhaust manifold bolt size
ZigZag Posted on: 2011/6/30 8:39
just wondering where to order new A14 exhaust manifold bolts from and intake while im at it
#2 Re: exhaust manifold bolt size
ddgonzal Posted on: 2011/6/30 9:13
Which bolts? Holding it to the intake manifold? Or for fastening the heat shield?
#3 Re: exhaust manifold bolt size
ddgonzal Posted on: 2011/6/30 9:27
Exhaust Manifold uses a bunch of different studs, but this is the early A14 type (yours may be different):
* 08223-82810 STUD-MANIFOLD M8X1.25 (9)
* 08223-83010 STUD-MANIFOLD M8X1.25 (2)
* 08911-20810 NUT-HEX (11)
* 14064-U6700 STUD FIXING EXHAUST MANIFOLDTO EXHAUST (3)
* 20602-A7100 NUT-FIXING TUBE END [long type]
The stud part numbers are broken down like this:
22: Stud, Medium carbon steel
38: diameter
30: Length
#4 Re: exhaust manifold bolt size
ZigZag Posted on: 2011/6/30 10:10
cheers D ill investigate further if this motor arrives
#5 Re: exhaust manifold bolt size
carps Posted on: 2011/6/30 15:12
Hey Ziggy i'm just in the process of putting all new nuts and bolts on my ute,
and you'l find most are a M4 and M8 so (metric 4mm and 8mm) in the engine bay an on the engine,
just depends what length you need i can go through all the one's i have just got and put on to find out the sizes you need
if you want?????
buy from coventry fastners their cheap and usually have everything you need...
hope that sort of helps, but let me know if you need sizes champ??? here to help
