Series 6 13b converted to single turbo fit in 1200?
From Narellan,Sydney
Series 6 single turbo fit in 1200 sedan?
Posted on: 2011/7/1 4:35
Re: Series 6 13b converted to single turbo fit in 1200?
From Melbourne AUS
yeah theyre pretty small engines. if it wont go in the boot put a towel down and sit it on the back seat
but seriously yeah there has been plenty of 13b turbo 1200's built for drag over the years
Posted on: 2011/7/1 6:04
1973 B110 A12
From Gold Coast
Lol Ange!!...Fit piece of piss, hardest thing is gettIng the angle of the engine right. Even with a large maddat tunnel my bellhousing is around 10mm from it. Check out my build if you wanna see how they fit.
Posted on: 2011/7/1 6:14
Thanks wardy.knew 13b fit but was originally going to goin series 5 but to hard to find so now going series 6.did you make your engine mounts?do you know if the maddat kit fits the series 6? Thanks mate
Posted on: 2011/7/1 7:40
The engine fits no problems, they even make an oil pan specifically for 13B into 1200.
The problem is fitting that large Mazda transmission...
Posted on: 2011/7/1 7:46
Ok sweet.I'll be making my own tunnel so hopefully I'll sort that out.did you guys need to make the tail shaft tunnel bigger?ddgonzal who sells the oil sump? Thanks
Posted on: 2011/7/1 8:11
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
fitting a rotor in is piss ant, i don't know why you'd modify the sump i never had to unless your doing it for performance reasons
Posted on: 2011/7/1 8:31
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
You don't need to modify the sump.
Moroso sells a baffled racing sump that is marketed as fitting the 1200
* 6.25 qt
* dual trap door baffles
Posted on: 2011/7/1 8:55
Ok sweet I'll see how it goes.you guys buy or make ur engine mounts?
Posted on: 2011/7/1 8:57
most people get a 12a front cover and modify rx3 front engine mount to suit
scroll down this page and it'll give you a good idea it got a couple photos
http://datsun1200.com/modules/newbb/v ... =ASC&type=&mode=0&start=0
thats a nice sump dd
Posted on: 2011/7/1 9:08
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
Stocko 1200 wagon
