desperatly need help!!! rear seatbelts
hey guys i am getting my car blueslipped tomoro and im rushing everything.
i have a 67 1000 sedan and when i bought it, it didnt have rear seatbelts. i was just wondering if they came out with them or not. if not will i still be able to get the car blue slipped without having to put them in?/or if they did come out with them where are the anchor points as i dont really wanna drill holes???
thanks heaps
Posted on: 2011/7/12 5:36
Re: desperatly need help!!! rear seatbelts
From three hills alberta
mine came with but i have read on here there an option. there is points but needs to be drilled
Posted on: 2011/7/12 8:07
They didn't come with rear seatbelts. Not the early 1000 anyway (2dr).
Even the fronts didn't come with any, that's why they bolted them straight through the pillars (as an add on).
So if there isn't any mounting spot for rear belts then I doubt they'll trouble you about it.
Posted on: 2011/7/12 8:39
Shouldn't need them if weren't standard or retrofitted later on.
Had. 68 mini, no rear belts so not required in vic.
Hopefully same in nsw
Posted on: 2011/7/12 9:39
