Re: WTB extractors or twin outlet manifold to suit 1000
I haven;t actually tried extractors, but I've heard that they don't fit well as you can only get them to suit 1200. Unless someone can give me a part number for some that will fit.
Posted on: 2011/7/11 12:59
Ill bring mine along so you can try them out
as mine on 2 and 3 outlets go straight down.
Posted on: 2011/7/11 13:05
From Perth
If you remove the grease nipple off the idler arm they fit just fine on cars I've put them on
Sometimes you need to massage the engine mounts too
Depends on what blocks in it
Want some pics ?
Posted on: 2011/7/11 14:39
From Coondle, WA Australia
I fit some 120Y extractors into my thou, with a little massaging. It was the collector (4-1) that gave me grief. With oxy in hand, i just moved the collector a little.
All good.
Ive also got a set of extractors that fit a thou nicly, but are stuffed and need to get a set rebent from them as a template, altough not as sexy looking as those of your chris.
Posted on: 2011/7/12 0:16
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Ive got no name ones here but they dont fit at all in the
engine bay with an A10. As for the genie headers Neil is
right on the cherry and the crippling is in the nipple,
so removing the nipple helps or heating with massaging
will help keep the nipple in its place all warm.
1. shows overall 4-1 design (marked hitting point below)
2. 2nd/3rd ex. outlet, going down instead of straight out.
3. Close up where they hit (5-10mm should clear nipple)
jpg  IMGP0039.JPG (190.88 KB)
737_4e1d44a2bcd6f.jpg 933X534 px
jpg  IMGP0041.JPG (194.76 KB)
737_4e1d44ac2b993.jpg 992X406 px
jpg  IMGP0043.JPG (187.77 KB)
737_4e1d44b51a4f5.jpg 736X426 px
Posted on: 2011/7/13 8:06
From Freo
It's ok to dent them to make them fit, they will hit on steering lock,
and the heat that close to the idler does the bushes no good...
Posted on: 2011/7/13 8:16
A15 PSI Project Motor
'72 CB750k,
with heating you can have 3cm clearance
a little heatproof tape will help
Posted on: 2011/7/13 9:22
I think I'll hold bac until I pick up the A12 and after the thou is on the road. I'll do my hunting and collecting then.
Posted on: 2011/7/13 12:22
The taller the motor the better the clearance.
Posted on: 2011/7/13 13:55
« 1 (2)
