(1) 2 3 »
THEY SAID IT COULDN'T BE DONE
From Albury
Looks like we have managed to jam some real brakes under 13" rims.
Fronts are landcruiser 4 spots on 200B or 240z struts with a drilled and slotted rotor.
Backs are going to be skyline discs and VS commodore caliper.
I have had heaps of people tell me that these brakes won't fit under 13" rims but we have had wheels bolted on them and they had clearance
Cheers
Bob
jpg  racecar01a.JPG (133.33 KB)
6695_4e2290c427f75.jpg 1072X804 px
jpg  racecar004a.JPG (132.26 KB)
6695_4e2290d65d571.jpg 1072X804 px
jpg  racecar 006a.JPG (143.70 KB)
6695_4e2290ee4cd32.jpg 1072X804 px
Posted on: 2011/7/17 8:37
Re: THEY SAID IT COULDN'T BE DONE
yes, good job. Also the 280ZX vented brakes fit under 13" alloy wheels (but not steel wheels)
Posted on: 2011/7/17 8:48
From Melbourne AUS
are they solid rotors? will they hold up stopping that blue rocket you drive?
Posted on: 2011/7/17 8:50
1973 B110 A12
sweet! do you have a picture of the bracket for the front?
Posted on: 2011/7/17 8:51
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
From Albury
there are no brackets they are a direct fit,just had to machine 10mm off rotor.
Hopefully these mothers will pull the old girl up Ange
Posted on: 2011/7/17 8:59
Thought 4 spot fit stanza struts and rotors, so would also fit 200b.
Great work though. I debating on a further upgrade on the front of mine too
Posted on: 2011/7/17 9:02
From mandurah
I had a set of those 4.pots bolted to my old 180b struts
Nice work ! ,those coilys are nice too !
Posted on: 2011/7/17 9:06
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From vic
nice are these of 80 or 100 series landcruiser
80 by the looks of them??
Posted on: 2011/7/17 9:08
From Geelong, Vic
im sure the brakes will pull it up, i'd be more worried about how many times in a row they will last being only a solid disc
if the calipers are to suit a solid disc then they are actually hilux calipers not landcruiser ones. Cruiser ones suit a 20 something mm thick vented disc which might be a better way to go eventually if you end up getting brake fade with the solid discs as im pretty sure they suit the same diameter rotor of the hilux ones but are a slightly different offset
but i think simon(sikyne) kinda beat you to fitting real brakes under 13s with these
Posted on: 2011/7/17 9:20
what setup is that?
Posted on: 2011/7/17 9:26
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
Stocko 1200 wagon
(1) 2 3 »
