#11 Re: THEY SAID IT COULDN'T BE DONE
PIGDOG Posted on: 2011/7/17 10:06
simons?
modified 200b strut
r32 calipers
Willwood 265mm x 29mm disc
Rears are also r32 with willwood rotors by the look of it
#12 Re: THEY SAID IT COULDN'T BE DONE
ANGE Posted on: 2011/7/17 10:18
i'd be more worried about how many times in a row they will last being only a solid disc
yeah that was my concern also
#13 Re: THEY SAID IT COULDN'T BE DONE
tommo73 Posted on: 2011/7/17 10:25
i can get 13" steel and aloy over mine
stanza strut n14 disc landcruzer caliper
build thred
#14 Re: THEY SAID IT COULDN'T BE DONE
PIGDOG Posted on: 2011/7/17 10:34
i was less than satisfied when i had the same sorta brakes on my car many years ago. you know, back when i used to have a 1200 that was on the road
mine was the landcruiser calipers some kinda camry vented discs and standard r31 rear brakes
possibly because they werent set up 100% perfectly
possibly because im picky with brakes
possibly because the next brakes they got compared to were full size r32 items(which were awesome)
but i just didnt like them
R-fast runs cruiser calipers and silvia(i think) discs on his race car and they are apparently pretty good, and also fit under 13s...once again beaten to the big brakes
But i think landcrusier calipers and what ever disc and r31 rear brakes are the text book big bolt-on* brakes to use under 13 inch mags
*note, brakes arent actually bolt on
#15 Re: THEY SAID IT COULDN'T BE DONE
1200rallycar Posted on: 2011/7/17 12:32
hilux 4 pot (s12+8 caliper) and U12 pintara discs, been running em for ten years under 13 wheels, and doubt i was first
bobs would be on vented discs? a solid would be too thin for the caliper to work in its proper range
the U12 pintara disc is vented if you want a good disc to use, some machining required to fit
great brakes, only downside could be the cast iron caliper is heavier than an alloy alternate
#16 Re: THEY SAID IT COULDN'T BE DONE
old_school Posted on: 2011/7/17 13:58
Im interested on some advice with this setup - hilux 4 pot (s12+8 caliper) and U12 pintara discs. (R31 Rear)
I have done this in my CA Coupe and under hard braking it locks the front right and under firm braking it pulls left.
Im using a 180B master and booster, I removed the 180B poportining valve assy that I had when I had stanza drum brakes rear and stanza disc front. I replaced the poportioning valve for one off of a Ford Laser and I belive this to be causing the problem.
I ran the s12 calipers with the stanza drum rear end and the 180B poportioning valve and the car pulled up straight, but you locked the rears under hard braking.
I curious to know how you guys have the master configured? I spoke to Maddat and they said they dont use a poportioning valve. Just straight from the master into a y splitter and then to the brakes.
Any thoughts?
And sorry for getting off track in your thread
#17 Re: THEY SAID IT COULDN'T BE DONE
PIGDOG Posted on: 2011/7/17 15:16
1200rc, they would be hilux calipers not land cruiser ones. They are pretty much the same caliper but the hilux ones are designed for a solid rotor instead of a vented one. So you would have actually been running 60 or 75 series calipers on your car not hilux ones. As far as I know no hilux came with the staggered piston calipers on a vented disc
Old_school. Can't really speak for running drums. But with disc all round and a 240k master cylinder I ran a willwood proportioning valve otherwise the rears would always lock up
#18 Re: THEY SAID IT COULDN'T BE DONE
ddgonzal Posted on: 2011/7/17 22:30
A big solid rotor won't cause brake fade on a street car in most driving situations. The bigger rotors shed heat pretty fast on such a light car as the 1200.
Now if you are racing a road circuit that is a different story.
#19 Re: THEY SAID IT COULDN'T BE DONE
bobthebuilder Posted on: 2011/7/17 23:28
Good to see I have created a bit of discussion and have learnt things from it.
Yes the rotors are solid 13mm rotor.
The calipers are stamped S12+8 but I can't slip in much wider rotors because the cut out is about 18mm.
Can I machine this cut out wider to accommodate a 22mm wide rotor.(is this what you had to do rc1200?)
Cheers
Bob
#20 Re: THEY SAID IT COULDN'T BE DONE
benny Posted on: 2011/7/18 0:11
You could also mill up a few spacers as the caliper are made of two halves. I have done this before so that I could accomodate a wider rotor. Longer fasteners are also used.
« 1 (2) 3 »
