(1) 2 3 »
ca18det specs
From Goulburn NSW
Hi everyone looking at buying some forged pistons for my ca18det rebuild what does the bore measure at,the guy that is rebuilding for me said to wait until the engine is apart because the bore could be 20 over or even under i know what he means but if the motor is in original condition wouldnt they all be the same.
Posted on: 2011/7/19 10:01
Re: ca18det specs
From Newcastle
the stock bore size is 83mm.
I would wait as well. Pistons generally go up in 0.020" Inch increments, with is 0.5mm.
If your bore is in bad conditions then they will hone the bore which generally puts you into the next ovesize category. I.e original bore + hone requires an 83.5mm piston.
hope that helps
Posted on: 2011/7/19 10:19
Re: ca18det specs
From Goulburn NSW
Ah thanks mcgee now atleast i know where he is coming from i was going to put 84mm pistons in anyway with the spool stroker crank which is 87.6mm stroke.Can u do the honing yourself or is it a machine job
Posted on: 2011/7/19 10:35
Re: ca18det specs
From Newcastle
Get the machining done professionally, it can make or break a good engine.
Actually if you are asking these question (no offence intended) it would be worth paying someone to assemble as well, or if you want to learn get someone (pro) to help you with the build
Posted on: 2011/7/19 10:39
Re: ca18det specs
From WTB 4 speed 60a & vb10 shell
why are so many people trying to go for the spool crank?
the stock ca18det crank is good enough for over 8500+rpm
Posted on: 2011/7/19 11:40
During times of universal deceit, telling the truth becomes a revolutionary act, Big Brother is watching you - George Orwell
Re: ca18det specs
From Gold Coast
more cubes = more torque/power i suppose.
I also suggest that if anyone is thinking of fitting forged pistons, measure the bore, if its still stock get the next size over pistons and the block machined to suit, even if the bore looks ok!
Alot of companies sell stock sized forged pistons (ie drop in), but with years of wear and tear on the engine they will very rarely have the right clearances.. which is cash down the drain
Posted on: 2011/7/19 11:56
New 1200 Drag project coming soon!!
Re: ca18det specs
lot of money for extra cubes better spent on a billet dual ball bearing turbo or go just go to a rotary :)
On an interesting note, someone in the states has a 650+hp qr23de using modded sr20de crankshaft due to full counterweight design and cheaper than billet.
Posted on: 2011/7/19 13:33
Re: ca18det specs
From hastings,vic
i thort that ca's dont like to be stroked??
bore to stroke ratio??? over square??
thats y thay go well,square ratio
my 2cents on ca stroking
Posted on: 2011/7/19 14:20
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
Re: ca18det specs
Xactly but if you are going to stroke it
doesnt it make sense to use a taller block.
Even if its weaker the side loading on a short
ca18 block is not worth the effort of stroking.
Posted on: 2011/7/19 14:40
Re: ca18det specs
From Geelong, Vic
+1 for money being better spent on things other than a stroker crank
And I wouldnt think that any good engine builder would put a new set of forged pistons in an old bore
But yeah, common sense to easier til the engine is measured up before buying pistons and bearings
One last thing, if buying forged pistons have a look at places in america for them. They were half the price of the exact same brand piston in australia when I bought mine and that was when the dollar wasnt as good
Posted on: 2011/7/19 15:31
(1) 2 3 »
