can you get too much spark?
From Malaysia
okay i can't get the answer after googling it, the basic question is, can you get too much spark?
lets just say I ran a badass coil, anything else stock with stock timing for my stock A12. would a big spark harm my engine?
Posted on: 2011/7/23 6:08
Re: can you get too much spark?
From Seattle, WA
You can never have too much spark. Only spark at the wrong timing.
Posted on: 2011/7/23 6:26
B110 sedan: L series and 4 speeds, the way they were
From Malaysia
i was told too much spark corrode the piston. i guess that is just a myth :)
Posted on: 2011/7/23 6:55
From Melbourne, Australia
As dd says, spark at the wrong time will cause you piston problems. If there it too much advance or pre-ignition from deposits getting red hot and igniting the fuel then you will have piston problems in time. That and an overly lean mixture. This is the most likely piston destroyer you can get.
Posted on: 2011/7/23 7:06
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
From Sydney, Australia
I've seen my Autronic cdi pull a 1 metre long spark from the cable to the engine using Bosch hei coils. Spark only needs to ignite the mixture.
In a wasted spark system you use a cycle to ignite whatever didn't burn during the exhaust stroke.
So that on every second TDC a spark iis used.
Once the timing is set, ignition lights it...
Posted on: 2011/7/23 11:07
You can have too much spark. The points and condenser can't cope with the back emf (electro magnetic force) and burn out prematurely. A points system can only cope with approx 30,000 volts, at idle and at cruise loads while hei copes with approx 40,000 volts helping you achieve a leaner burn.
Posted on: 2011/7/23 11:17
From Malaysia
lets just say i use electronic dizzy, would that still be a problem?
i have known a coil rated at 50kV. but still don't dare to use it as it might fry the dizzy.
dattodude 1 meter spark? that must be a sight to behold!
Posted on: 2011/7/23 13:00
From Seattle, WA
The factory Datsun electronic ignition is 50,000 volts.
Posted on: 2011/7/23 17:11
Quite a regular
From Olympia, WA, USA
Here you go... a 500Kv spark. One meter is nothing :)
Jacob's Ladder: 500kV Switch Opening
Posted on: 2011/7/23 17:37
"Horsepower... May you always have enough"
From Malaysia
your stereo wouldnt be happy about this lol.
Posted on: 2011/7/24 0:43
