#1 Leaking Mater Cylinder
camosphere Posted on: 2011/7/29 4:36
Hi. I just fitted a sunny booster and master cylinder to my sedan on the weekend. The brakes are working well know. I went to check a few things today and the front brake reservoir was almost empty. There is a leak between the front of the booster and the master cylinder. Does anyone have any idea what this might be a symptom of ? Any help greatly appreciated.
#2 Re: Leaking Mater Cylinder
Shoota_77 Posted on: 2011/7/29 4:52
Most likely one or both of your primary piston seals have gone.
Quite common if the master has been laying around a long time. The seals are like a cup and don't take much to wear down or perish. Also, if the cylinder has a steel liner, they can rust from the outside in (brake fluid is hygroscopic (I think that's the word!) meaning it attracts water). This allows fluid to leak past the seal and can also wear out the seal prematurely by rubbing over the rough surface of the rust. Whack a kit through it (if the bore is still ok) and it should be all good. They're very easy to rebuild. Just get a tube of rubber grease and grease the seals well before installation.
#3 Re: Leaking Mater Cylinder
randoli Posted on: 2011/7/29 5:14
Is that like Tah'mater - without the "Tah"? Surely it's part of his character, I wouldn't worry about it :)
jpg  mater2.jpg (11.24 KB)
10135_4e323432e6eb8.jpg 249X202 px
#4 Re: Leaking Mater Cylinder
camosphere Posted on: 2011/7/29 5:17
Thanks mate. Thought this might be the case. Will try and track down a newy. It's a 13/16 bore. Anyone got one? For the record adapting a sunny booster is not a straight bolt on. Four holes need to be drilled through three layers of steel firewall, plus the master hole needs to be made substantially larger. Which is hours of fun with a drill, grinder and die grinder with limited space(insert sarcasm). The splitter also needs to be mounted to the strut tower. Two more holes to be drilled with limited space. This is not a huge deal. I would strongly suggest to anyone doing this conversion to do it with the engine out if possible. A plasma cutter would speed up the process a great deal. All the steel brake lines also need to be replaced as they run from the splitter as opposed to from the brass bias valve. Luckily this system was in a car I already had so I had everything to swap over. The car that had this system also had a modified brake pedal to accommodate the sunny booster plunger. The pedal has been cut recessed and welded. In hind sight I would have preferred to make a adapter plate to the existing bolt holes in the firewall and then a plunger bar of correct length for the standard brake pedal. Just thought I would add this info as there is a few points not mentioned in the teck wiki. And for the record my supposed soft H89 head is still working fine. I have checked the torque setting twice now. Nothing has loosened at all after @ 1000k's. Thanks again.
#5 Re: Leaking Mater Cylinder
camosphere Posted on: 2011/7/29 5:21
Sorry....you have lost me???
#6 Re: Leaking Mater Cylinder
camosphere Posted on: 2011/7/29 5:23
Whats's the mater with a fewww tyyypooos haha
