For Sale Sunny Race Car
From Victoria
For Sale is my Datsun Sunny Race Car. Its in good condition and hasn't been used much.
Specs:
A15 Bored, 3 Puck button Clutch, Toyota T50 5 Speed with custom adapter, Stanza Diff and sway bar with a 4.9 Ratio, Koni Shocks, 240K uprights with adjustable strut tops, Brakes Front 240K 2 spots with comp 2 pads rear proportioning valve & R31 Skyline rear disk brakes, Tires Toyo R spec,
Engine Spec:
Twin 45mm Webbers
Electronic Dizzy
Lightened Flywheel
JTS Ported A15 head stainless steel oversize valves double valve springs.
Bored block with Mazda flat top pistons
Polished and shot peened rods
Full engine balance including crank
Drilled oil galleries
ARP bolts
Baffled sump
Custom ground cam
Plus plenty of spares
The interior is stripped out but could be restored
This engine and gearbox was in my Clubman race car wich some of you no off it has won 2 Australian titles many state titles and many track records. This engine has been bullet proof and has never let me down. 8750 rpm and 106RWKW. Great little car ideal for a first timer.
Price: $5,000 Call 03 9728 1969 0408 172 010
Posted on: 2011/7/5 14:46
Edited by Clubman on 2011/7/9 9:12:23
Re: For Sale Sunny Race Car
do you have any spare sunnys as roadcars cheap?
Posted on: 2011/7/31 7:29
From Victoria
I could put a A12 motor and gearbox back in this one and it could still be registered. And it would be a lot cheaper than it is now.
Posted on: 2011/7/31 8:42
Hey mate engine sounds wicked! Would you seperate the engine and box? If so how much? I read there you had koni's would they fit a 1200 ute? If you don't mind me asking what are they worth? I believe koni doesn't actually make inserts to fit straight into 1200 struts however they will custom make them to order. Cheers ed
Posted on: 2011/7/31 13:29
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
