fuel and temperature gauge problem
Quite a regular
From Philippines
nissan sunny 1200 pick up
hello there.
just want to ask if you guys know where to find the voltage regulator for the fuel and temperature gauge because both of them are not working and i'm just clueless on how to fix this.
i really appreciate if someone here could give me an idea on how to fix this.
am having a big problem when refilling with gas and really i don't know if the engine is overheating or not.
thank you so much.
Posted on: 2011/8/1 6:57
Re: fuel and temperature gauge problem
The instrument panel voltage regulator is attached to the water temperature gauge. It is integral with the gauage and not available separately.
* 24880-H1000 METER ASSY-WATER TEMPERATURE
For overheating, listen carefully for any sign of misfiring. Immediately pull over and turn off engine. Also look for signs of steam at front of bonnet. My gauge has not worked in four years. No overheating yet.
Posted on: 2011/8/1 7:06
Quite a regular
From Philippines
i see. thank you so much for this.
i thought i could go and replace that part.
what i would do now is buy a separate gauges.
thank you so much. really appreciate it.
Posted on: 2011/8/1 7:19
From Melbourne AUS
make sure that you dont have a bad earth
Posted on: 2011/8/1 7:29
1973 B110 A12
Quite a regular
From Philippines
i will also check that one cause lately when i switch to park light or signal light the dashboard light becomes slightly dimmer. other times when i start the engine both gauges start to rise then goes down again as the engine idles.
Posted on: 2011/8/1 7:35
