« 1 ... 18 19 20 (21) 22 23 24 ... 37 »
Re: Melbourne cruise :14th August- route updated pg:1, rest is whoring as usual
Just take the tool kit out, pour petrol and strike a match. Fixes everything.
Yeah sounds good Ange, Macas on Sydney rd again? Time?
Posted on: 2011/8/6 3:57
jayco wrote:
a disaster of datsuns?? is that the collective noun?
Bahhahaha. I was origionally thinking of a 'Dissapointment of Datsuns'
Mik, you could srive straight there from your place. Surely driving up to Ring Rd from your place would be massively out of your way. Besides, You're not a westie. You're a north boy.
Posted on: 2011/8/6 4:11
Could but it's nice to cruise with Ange. Should cut across to eastern. Not that bad in the morning
Posted on: 2011/8/6 4:14
Well 1 week to go. And what would it be without dramas.
Spent this morning fixing Heater leak when driving home from fixing tap at inlaws instead of superfattos my heater let's hit coolant dribble out onto my feet. Yay :(
Fixed though and pray no other leaks or any head gasket issues- it's got to be condensation from sitting not driven enough.
Any one else with issues or progress reports?
Posted on: 2011/8/7 8:02
From Melbourne, Australia
A14 Engine in, mostly wired up. Just need to finish off wiring and hoses, put radiator, fan, air cleaner, etc back in. Then off to exhaust shop to get new exhaust plumbed in. Going to convert to electronic dizzy too if time.
Stanza struts are now welded together, just need to grind off welds, weld on coilover sleeves then repaint them. Need to drill out adjustable strut top bush 1mm larger to accept different inserts.
Lots to do, not much time!
Posted on: 2011/8/7 10:58
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
From Melbourne AUS
well ive got a new exhaust on the ute after the old one expired
and this will be my first outing after fitting a 4.875 diff centre so that
should do wonders for my already fantastic fuel economy
im pumped up for an all datsun day
also im happy to pre meet anywhere and take either route to the meet point...
just let me know where and when
Posted on: 2011/8/7 13:05
1973 B110 A12
Cadet is running! woot! im stoked, one week for refinements like temprature and boost gauges etc and putting the interior back in. went well, no lag, was dark and wet outside though, hopefully do a bit more driving tomorrow to see what it goes like
Posted on: 2011/8/7 13:07
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
tomo and rc... ca showdown... i pout $5 on mrs rc saying no no no
Posted on: 2011/8/7 13:14
as for meet will message you tomorrow ange- i rckon up eastern quicker and more direct then ring road. plus you place to city with 4.8 and 5 speeds, im sure your head will be buzzing that wou will kill for 60kmh zones.
Posted on: 2011/8/7 13:16
From Melbourne AUS
your probably right mik, it revs at bang on 4000rpm at 100kph
it sounds a lot, but is still less than half the rev range
Posted on: 2011/8/7 13:19
1973 B110 A12
