Water outlet?
From Los Angeles,CA
Anyone know a good way to remove the lower water pipe from the block? The one that comes off the water pump to the lower radiator outlet.
Posted on: 2011/8/8 3:21
Re: Water outlet?
I just did this last week for the breather tube. I would guess the water tube comes out the same way.
Fasten the Vice-Grips then hammer the pipe out
Posted on: 2011/8/8 4:14
Re: Water outlet?
From Freo
thats the way...
and then bang the new one in..
Posted on: 2011/8/8 5:10
A15 PSI Project Motor
'72 CB750k,
Re: Water outlet?
From Los Angeles,CA
"Fasten the Vice-Grips then hammer the pipe out"
Hammer where? You mean like back and forth, using the Vice grips as a handle?
Posted on: 2011/8/8 5:22
Re: Water outlet?
This is the same way I use for removing the similar
sized water outlet tube at the front but with a piece
of leather to avoid bite marks. VGrips are saviours.
Posted on: 2011/8/8 5:26
Re: Water outlet?
Good question. I just hammered it straight off. Away from the block. Only took 3 or 4 medium taps. YMMV.
Posted on: 2011/8/8 5:27
Re: Water outlet?
From Los Angeles,CA
Ohhhh... You mean you hammered on the vice grips?
Posted on: 2011/8/8 5:36
Re: Water outlet?
You got it. I hammered on the vice grips.
Posted on: 2011/8/8 5:43
