#1 Water outlet?
LOWTECH Posted on: 2011/8/8 3:21
Anyone know a good way to remove the lower water pipe from the block? The one that comes off the water pump to the lower radiator outlet.
#2 Re: Water outlet?
ddgonzal Posted on: 2011/8/8 4:14
I just did this last week for the breather tube. I would guess the water tube comes out the same way.
Fasten the Vice-Grips then hammer the pipe out
#3 Re: Water outlet?
Dundee1000 Posted on: 2011/8/8 5:10
thats the way...
and then bang the new one in..
#4 Re: Water outlet?
LOWTECH Posted on: 2011/8/8 5:22
"Fasten the Vice-Grips then hammer the pipe out"
Hammer where? You mean like back and forth, using the Vice grips as a handle?
#5 Re: Water outlet?
D Posted on: 2011/8/8 5:26
This is the same way I use for removing the similar
sized water outlet tube at the front but with a piece
of leather to avoid bite marks. VGrips are saviours.
#6 Re: Water outlet?
ddgonzal Posted on: 2011/8/8 5:27
Good question. I just hammered it straight off. Away from the block. Only took 3 or 4 medium taps. YMMV.
#7 Re: Water outlet?
LOWTECH Posted on: 2011/8/8 5:36
Ohhhh... You mean you hammered on the vice grips?
#8 Re: Water outlet?
ddgonzal Posted on: 2011/8/8 5:43
You got it. I hammered on the vice grips.
