Re: a novel type of blow off valve - PCV problem on CA18DET
From Brisbane
another idea to put into the mix. disconnect the line that runs to the back of the inlet manifold. block off manifold side. Does sound like the block is been pressuried pushing oil into the head.
jpg  blank.jpg (56.74 KB)
13026_4e4911e7a9cba.jpg 440X260 px
Posted on: 2011/8/15 13:35
Subject Poster Date
     a novel type of blow off valve - PCV problem on CA18DET 1200rallycar 2011/8/15 10:28
       Re: a novel type of blow off valve - PCV problem on CA18DET 1200rallycar 2011/8/15 10:34
         Re: a novel type of blow off valve - PCV problem on CA18DET 1200rallycar 2011/8/15 10:35
       Re: a novel type of blow off valve - PCV problem on CA18DET levey 2011/8/15 10:58
         Re: a novel type of blow off valve - PCV problem on CA18DET 1200rallycar 2011/8/15 12:21
       Re: a novel type of blow off valve - PCV problem on CA18DET oda70 2011/8/15 12:44
         Re: a novel type of blow off valve - PCV problem on CA18DET 1200rallycar 2011/8/15 12:50
       Re: a novel type of blow off valve - PCV problem on CA18DET oda70 2011/8/15 12:59
       Re: a novel type of blow off valve - PCV problem on CA18DET oda70 2011/8/15 13:02
         Re: a novel type of blow off valve - PCV problem on CA18DET 1200rallycar 2011/8/15 13:22
           Re: a novel type of blow off valve - PCV problem on CA18DET PIGDOG 2011/8/15 13:46
       Re: a novel type of blow off valve - PCV problem on CA18DET oda70 2011/8/15 13:35
       Re: a novel type of blow off valve - PCV problem on CA18DET tommo73 2011/8/16 0:51
