points gap
From Goulburn NSW
Hi guys going to change the points in my ute but dont have a manual can anyone tell me what the points gap should be,its a 1200.
Posted on: 2011/8/16 8:34
Re: points gap
From Sydney, Australia
0.5mm from memory
Posted on: 2011/8/16 8:38
B110 sedan
Re: points gap
From Malaysia
Posted on: 2011/8/16 9:18
Re: points gap
From Goulburn NSW
HI Bakat i dont know enough about engines for it to register,i dont know what dwell is i must be the only guy on the forum that doesnt have the knowledge.Anyway i was just going to take the points out put the new ones in and set the gap can i do that or am i going to run into trouble.
Hi da75ez is the .05 accurate .
Posted on: 2011/8/16 9:44
Re: points gap
Point gap: 0.45 to 0.55 mm (18-22 thousands inch)
Posted on: 2011/8/16 9:46
B110 sedan
Re: points gap
From Malaysia
you can set the dwell by using feeler gauge, 0.45~0.55mm, or you can use dwell meter which is more accurate to set the points.
Posted on: 2011/8/16 9:50
Re: points gap
From Goulburn NSW
Guys do i also set the points when the shaft is on the open point if u guys know what i mean.Whats the gap for plugs.
Posted on: 2011/8/16 10:02
Re: points gap
Yeah when the points are at the most open point on the corner of the rotor.
Posted on: 2011/8/16 10:13
B110 sedan
Re: points gap
From Goulburn NSW
thankx guys much appreciated,now can u tell me the gap for the plugs.
Posted on: 2011/8/16 10:22
Re: points gap
From Malaysia
set the gap at the apex of the rotor.
plug gap: 0.7mm~0.8mm
Posted on: 2011/8/16 10:24
