Re: Wheel alignment problems
Nah, you must first find center as superfatto described:
do a swing test turn the wheel one way and count the turns from where the wheels apper to be straight and then do the same the other way! If they are the same then the steer rack is centered and the wheel isn't so u can remove the wheel and center it yourself(but leave the wheel nut on a turn so u don't ko yourself!)
After that is confirmed, then you can adjust toe.
Posted on: 2011/8/18 1:42
Subject Poster Date
     Wheel alignment problems elemental_funk 2011/8/17 2:46
       Re: Wheel alignment problems Anonymous 2011/8/17 3:21
         Re: Wheel alignment problems ddgonzal 2011/8/17 4:15
           Re: Wheel alignment problems benny 2011/8/17 5:27
             Re: Wheel alignment problems Anonymous 2011/8/17 5:32
               Re: Wheel alignment problems supafatto 2011/8/17 8:54
                 Re: Wheel alignment problems elemental_funk 2011/8/17 10:16
                   Re: Wheel alignment problems elemental_funk 2011/8/17 10:18
       Re: Wheel alignment problems ddgonzal 2011/8/18 1:42
       Re: Wheel alignment problems jmac 2011/8/20 10:21
         Re: Wheel alignment problems estyre 2011/8/20 14:08
