« 1 ... 3 4 5 (6) 7 8 9 10 »
Re: Targa rally 2011 25th-28th August , Perth, WA
From Coondle, WA Australia
If you want to fit in, and you think beef jerky is it, well you have much to learn your padawan. Red cans is a start, funnells, shotgun cans, boomsticks, boot skulls,
Posted on: 2011/8/18 13:48
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Perth WA AUS
Bring a helmet and safety gear, you never know what Boris will be upto and you need to be prepared! :)
Posted on: 2011/8/18 13:54
Datsun 1200 2Dr sedan.
From Albany, Perth Australia
flannelette is a must to fit in as well...must wear old ratty steelcaps too
Posted on: 2011/8/18 14:20
1200 Smerf Mobile
oil skin jacket helps..
And dont get confuse us hilbillys with bogans. very differnt breed them
Posted on: 2011/8/18 14:24
i didnt say anything about a holden with a chevy badge did i? hahaha bloody idiot bogans dont even know what car they have
Posted on: 2011/8/18 14:30
1200 Smerf Mobile
good good. I certainly dont want to be confused with a bogan.
Area 7 sung a song that says it best.
Nobody likes, Nobody likes, Nobody likes a bogan!
Ill put it on the jukebox wheny you guys arrive.
As for ratty steel caps, well the general rule here is that if your steel caps are exposed, if they are off your feet, the caps will get welded together!! At at Campbell lot, there are enough welders to sort that. (200 amp arc, 100 amp arc, 130 amp gasless mig, 220 amp mig, 150 amp TIG) and plenty of rope to tie people down with.
Posted on: 2011/8/18 23:35
From Freo
Feed 'Em to the Pigs..
Posted on: 2011/8/19 1:02
A15 PSI Project Motor
'72 CB750k,
From mandurah
Theres pigs !? Can we grease one up and chase after it
Or at least grease nige up and chase him around ?
Posted on: 2011/8/19 2:24
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
hell yeah there are pigs out my way. Im sure there are some in the block behind us, and I know there is a big population in the Julimar Forrest about 15 mins drive away.
Does anyone have an old wood chisel that they would let me borrow for some tyre regroving duties at Targa?
Posted on: 2011/8/19 2:27
From mandurah
Wood chisel ? What about a sliding bead breaker ?
Posted on: 2011/8/19 3:06
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
