« 1 (2) 3 »
Re: A15 Dyno Results
From Adelaide
It's a good start.... Just need to give up my job so I've got time to work on it more than once a fortnight.
Posted on: 2011/8/25 9:03
From North Coast NSW
God i need to get mine on the dyno once its done! Really want to see what my a15 makes
Posted on: 2011/8/25 14:15
in need of coupe parts!
just wondering if an A10 makes around 64hp for the extra
50% capacity increase an A15 should make way more power.
eg. 64hp ate + 32hp (50% more due to 500cc increase from
988cc to 1488cc) = 96hp. Just theoretical though as
it will also consume 50% more fuel, carb and exhaust size.
So a weber 32/36, headers and elect ignition should make
an a15 have 96hp ate or 80hp atw (60kw)
Posted on: 2011/8/25 15:11
From mandurah
If your correct and an a15 with weber and good ignition makes 80rwhp how much would a fairly hot 15 go ,more comp , port job ,valve job ,big cam twins and a good quality igniton system
Anyone got an idea of what one would make ?
Posted on: 2011/8/26 3:54
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From melbourne
My 1000 coupe race car
with stock a15 short with lightened fly wheel 6kg with standed a12 gx head shaved 60 tho, electronic ignition,twin 40mm webers and 4,2,1 extracters makes 80kw at the wheels (98.4at the fly wheel)
Hope this helps
Cheers Mark
Posted on: 2011/8/26 9:58
A14 1000 coupe road car
A15 1000 coupe race car
A10 1000 ute mat black (rat ute)
1000 wagon 4age 20 valve(next project)
From Perth
My A15 (1526cc) with low comp and reasonable head made 98.7hp atw
Posted on: 2011/8/26 11:59
Datsun racing 1000s prepared by Gordon Dobey
supposedly made 130hp at the flywheel @ 10,000rpm
Mark what rpm did it make that power?
Posted on: 2011/8/26 12:19
Mopar Marks simple setup with stock gx valves stomps on this
more sophisticated and expensively setup A15.
http://www.ebay.com.au/itm/Datsun-A15 ... ories&hash=item20bc4941bf
Posted on: 2011/8/29 9:41
Almost looks like an attempt at the old lag wagon a14. Still 130hp a15 would be fun
Posted on: 2011/8/29 10:44
From Ringwood, Melbourne, AUS
Dunno about stomps on it, there is more than 20hp diff there but I bet that extra 20hp cost a fair bit to find..
Posted on: 2011/8/29 12:50
Deano
« 1 (2) 3 »
